Looking at doing some sort of heat shielding for my 2 pods that are just sitting there sucking hot air at the moment but wondering what to do about getting some cold air into them afterwards.
My gtst was easy as it already had a nice 3" hole from factory right where I wanted it.
My question is it safe to cut a 3" or so hole right below were the pods are then I could do the induction easily, just ive heard something about how it makes all the support weaker on that side etc etc. It probably wont be so obvious just looking at it from the engine bay.
Only other option I can think of is the headlight replacement but I want it for street use so that would be no good.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/
It has the stock airbox, but who knows what in it or if the box is modified?
LW.
OK I'll go another route.
Stock air box, Piper cross panel filter, custom stainless pipe to replace stock rubber one between turbo/s and AFM.
maybe ask Sydney Kid the max power he has seen from that set up on a GTR.
Honestly, when I had my GTST (R32) and had a pod filter, the thing was only producing like 155rwkw and the engine bay was so hot, the intake temps were like in the 60's during sydney traffic.
so imagine the engine bay of a gtr with 2 turbo's producing obviously more power.
and 2 pods taking up the same room.
even hotter air there for sure.
the stock air box is good.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222333
GTST: I am aware of Gary's view on Pipercross filters: in fact I will be putting one in the (stock) airbox of my R32 GT-R very shortly.
My point was more that although the Mines R34 may have the "stock airbox", for all we know its been completely changed on the inside. I'm not sure it makes a particularly good point of comparison given all the unknowns surrounding the car.
LW.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222395
LW - I was just trying to make the point of the stock GTR air box with a panel filter is going to be a better option that PODS in the engine bay.
AND it is cheaper to buy a stock air box and new panel filter, than it is to buy an aftermarket heat shield/air box which probably still uses tha factory snorkel.. to shield off the dirty used pods that would have come with the car from japan.
you will be able to produce the same power (possibly more) if using stock turbo's and maybe even with after market turbo's..
the cost of buying a stock airbox and panel filter is going to be cheaper than buying a heat shield for sure. and give a better result.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1222437
To answer your original question I drilled a 3" hole below my rear pod. I don't see how it has any effect on the structural integrity on that side. I have two 3" flexible hoses in the front bar. One running through the hole to my rear pod, the other through a factory whole under the headlight to my front pod.
Hope that helps.
Gary.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1224680
theres a factory 3" hole under your front pod? ah thats right yours is 32 so probably different.
You reckon 1 3" hole would be enough for the 2 pods? dont really want to cut 2 holes. Might cut 1 hole and put a scoop intake on also (hope it doesnt look ricey :Oops: )
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1224876
The factory hole is under my headlight and was used for part of the air box setup that went to a resonator box. I thought the 33's would have had it too but I could be wrong. It is more like a rectangle hole next to the carbon canister. One big hole is probably enough though.
https://www.sau.com.au/forums/topic/65156-cai-on-33gtr/#findComment-1225169
    • Yeah, my moulds and seals are 32 years old now. I think I will continue to not use a pressure washer on it.
    • I hear the old "I'd never use a pressure washer on my motorbike" BS in the dirtbike community too.  The only people that have had a problem from using a pressure washer on anything are the people that aren't using them properly.  If you hold the wand any more than 45 cms away from pretty much anything (radiators, wiring connectors, paint, etc) you aren't going to cause any damage.  We've had detailers wreck moulds and seals on cars at work before and the only reason why is they held the pressure washer too close and on the one spot for too long.  If you have 5% more brain power than a detailer then you know not to not do that and you'll never have a problem.
    • I'm pretty much healed up post surgery so I spent another almost full day out in the shed re-arranging everything to make room for all of the shit that I've taken off the car.  I need to get everything off the floor and away from the car for when I start making a massive mess stripping off the remaining body deadener and then for the the painting process.  Almost got the shed to a point now where I feel I can actually start working on the car again (clean shed clean mind or something!).  Almost 11 years of accumulated car parts, building supplies, tools, junk, etc have taken a long time to get in some sort of order again!  Most stuff is now boxed up and in the back shed if it's not car related.  Most people would still be horrified walking into my shed but it's significantly better than it was before!   For those that saw my separate post the other day, yeah I ordered one.... This version- I convinced myself to stop being a clown, wake up to yourself and realise it will take you 5 weeks to make one by which stage you're over working on the car again...  Maybe I am getting on top of my "mental ailments" and making smarter choices.... $1450 delivered which will take my miserable half-dutch arse a few days to get over having spent that much!  If I don't have a use for it straight away after my car is off it I might even see if there is a "rental market" for them.  See if anyone wants to hire it for a period of time.  $25 a week or something like that.  I'll worry about that when my car is actually ready to come off it though as that might be a while away!! There's now no excuses now for not ending up with an underside you could eat off! Away for kids sport the next few weekends so hopefully can get the rotisserie assembled ready to go for the car to go straight on it the next available weekend.
    • I always use my Karcher, but it's only a little one that I picked up from Supercheap  The only issue I ever had with a pressure washer was when I was a kid cleaning coaches, they had a hi-po industrial sized petrol jobbie that would strip paint if you got to close I saying this, we have a fairly high power washer at work with a diesel powered heater that sprays water at about 60°c, it works great for removing old wax and road grime on the underbody after some foam cannon action, albeit from a "stand off" distance of a few feet
    • Sorry no - The sandtrap adventure ended the day, happened at the end of the last session. At that time I wasn't hearing any weird noises nor were the brakes shuddering anymore. It was only when watching the videos that I remembered I had these sounds early on!
