I'm looking at a white '87 aussie Silhouette.
The guy that currently owns the car doesn't realise the car's potential and has been running it on regular ULP so it feels like something is holding it back (knock sensor?)
He bought the car 4 years ago and hasn't done a thing to it except for routine maintenance.
All mods are 7 years old and engineered and include
R33 RB25 DET and 5 speed
Front mounted Supra intercooler
HR31 struts and brakes
Koni strut inserts and shocks
2.5" exhaust
Things I've noticed that need attention
Factory tacho was never made to work with new motor.
Oil pressure gauge very erratic (reads high and flickers)
No boost gauge
The main plug to the TPS isn't hooked up but the one on the wire is.
Apart from this the car is very tidy for it's age but shows the usual r31 wear and tear on the interior.
It drives very well and I'm sure it would pull harder with some Ultimate in the tank.
What would it be worth and should I buy it?
https://www.sau.com.au/forums/topic/65194-r31-rb25det-sleeper-should-i-buy/
The oil pressure guage is a very common problem with the aussie R31, actually the whole instrument cluster can do weird things.
Good info here
http://darkhalf.r31skylineclub.com/guages/index.html
or r31skylineclub.com
Also.. i saw a R31 2 door coupe on jspec importers website last week. it had RB25 as well and looked sweet. Price was estimated between 7 - 11grand.
  • 1 month later...
I'd buy an Sr20det silvia instead for $14.5k..
Nah you should buy my R31 for 14 :)
http://www.skylinesaustralia.com/forums/sh...ead.php?t=67397
faster,
No way :)
better at stopping
Maybe...just :)
, better around corners,
Possibly :)
looks better..
Never :)
do u mean this one?
http://www.autotrader.com.au/photodisplay....r=N15503438_31C
or this one?
http://www.autotrader.com.au/photodisplay....r=Y15504211_31H
(i know which one id be looking at, and its a long drive away :D
The 2nd one is a coupe.. so it's much more likely to be the 1st link.
Looks like a good clean car, with a nice motor in it. :headspin:
I reckon it sounds ok
but running it on regular unleaded could be a problem.
Since it's already got import struts you can stuff R32/33/34 brakes onto it
it can be made to handle well for what it is, but the live axle rear end is always going to hold it back.
If you want something that's going to take any corner at a stupid speed and stop on a 5c piece then you're going to be dissapointed.
If you want something that's a little different and something that's going to be a nice street car (not track car) then I reckon it would be fine.
My own Silhouette is having an RB25 conversion being done to it right now, so I'm a little biased :wassup:
If you're buying it from interstate then you're going to have make the whole instrument cluster work if you want it to pass rego, so that tacho is going to have to be fixed (Speedo as well?)
I hope it has an RB25 gear box to go with the RB25 engine.....
It almost sounds like a scrappy conversion, no working tacho, funny wiring
I find it funny that it's been engineered without a working tacho and no boost gague
If you think it's performance is a little funny, especially for a series 2(3?) RB25DET, then you should get it checked out by someone that knows heaps about it
a 3' exhaust will certainly give it a bit more shove
I dunno that's just my thoughts, sorry to ramble :D
  • 3 weeks later...
here's another r31, but perhaps slightly more obvious than a typical sleeper
http://www.autotrader.com.au/photodisplay....r=N15618796_31D
guess it depends if its rb30det or rb30et whether it's worth it or not
    • Howdy friends, So another weird one today, I was looking into replacing some broken clips holding the front grille for the R32 GTR (part number 01553-03831), and noticed the brackets which are supposed to hold the grille in place were also missing 😑. I do recall seeing this issue many years ago, but didn't fix it at the time. A quick look on eBay and I was able to find the genuine brackets, along with all the screws which suited the headlights (part numbers 26042-08U05,26092-08U05). Happy days!....  Once they arrived however there was an extra nut in the packaging which implied that there should also be a bolt or a stud, and sure enough, after a bit of searching I found this thread from 2013, and @Ants clearly shows a stud should be present. Reading around a bit more, it's possible the headlights on my car are the "povo pack" headlights as mentioned by @funkymonkey in this thread way back in 2008. This could explain why the studs are missing on my set of headlights. Looking at the headlight diagram I wasn't able to see a suitable part number for the stud itself. The headlight did indeed have a recess that looked like it would accept a stud, but interestingly no thread or anything obvious how the stud would be affixed to the headlight, I suspect it may have been glued in, press fit, or melted into the plastic at the factory. Another member may be able to clarify if they happen to have a genuine set of N1 headlamps. The only thing we have to work with within the recess is a keyway which likely is there to prevent the stud from rotating within the recess. In any case, back to 3D printing, I put together a model which acts like a pug with a friction fit inside this recess, making use of the keyway so it doesn't rotate while tightening a bolt. Printing in TPU will allow it to slightly swell making a nice snug fit without cracking the part. I've designed the adaptor it to accept an 20 mm M6 bolt (stainless with a cap head in my case), as opposed to the standard M5 stud and I made use of the standard galvanised split washer that came with the genuine brackets from Nissan. Once the bolt and screws were all in place, giving the bracket a gentle shake gave the classic "shaking the car" feeling, very solid, which gives me confidence this is going to be able to hold on much better than the janky solution which seems to have been here for the past decade or so. Overall I'm really pleased with how this turned out and maybe there are more people out there running these headlights without a centre stud at all! Link to the freely available model on Printables: Click here Regards, Sean
    • Hey everyone, This is my first post apart of the introduction. I tried searching a bit on the forum but couldn't really get a straight answer. I got the car to my mechanic as I felt it being weak. It seems that it was missing on two cylinders due to the injectors. I had all my injectors clean and the car runs much better. The mechanic also confirmed my suspicions that the cat is clogged and needs to be tackled asap. The cat rattles a bit and the hot exhaust warning frequently lights up when driving after getting the injectors clean. In my introduction I was asked about what modification I might be interested in and mentioned a cat delete. From what I was told, this is not really beneficial on the RB20DE and there are more cons than pros.  Could perhaps anyone give some suggestions on what the best course of action would be since the current cat is toast and needs to be removed/replaced anyway? I can also sometimes smell a strong smell of fuel, but I'm not sure if this is related.
    • Hope the cans went down well at least
    • 255 can't go wrong with the price.
    • When I was replacing my pump due to being stranded in the wrong state, I went with the Deatschwerks 320lph kit. It is a direct plug in to the stock wires, harness, everything. It comes with a plug... but you can plug the OEM plug directly into this thing. https://justjap.com/products/deatschwerks-dw300-fuel-pump-nissan-s13-silvia-r32-r33-r34-skyline-c34-stagea?currency=AUD Downside: Won't actually flow that much on boost if you want to push it on E85, but it's comparable to the 040/255 etc. Little more actually.
