Hi everyone i am new here.
I want to ask if anyone has come up against the problem that I am experiencing
with my R32 GTR drag car.
when I run the car on the 1/4 mile it wants to change lanes,no matter how hard I try to hold it straight
it wants to pull me either into the wall or into the other lane ????.
It feels like the front steering is toeing out but it is not,it is set at one degree toe in
the car has OS Giken diffs front and rear,the car has HKS drag dampers not sure what springs are fitted
the rear runs with 1 degree positive camber and one degree toe in.
Here is some info on the car and a few photos if anyone is interested
Car weighs 1210 KG.
Cusco front adjustable tie rods.
HKS drag dampers with HKS top mounts.
Midori top front adjustable camber mounts.
Border hicas removal kit.
Midori rear beam location kit.
Cusco rear top adjustable camber rods.
Midori rear tie rods.
Hope someone can give me some ideas to try
thanks Keith
https://www.sau.com.au/forums/topic/65227-help-with-r32-gtr-drag-setup/
Keith, how much power is the car making? I'm guessing over 800ps? Also what tyres are you using, and is the ATTESSA system running as standard or are you using some kind of torque split controller?
BTW good effort on getting the car down to 1210kgs!
Hi mmmgtir
Not sure on what power it is making to be sure
It is a Trust 2.7 with 290 11.5mm Tomei cams,it runs at 2.5 bar boost with a pair of 3037S
turbos,rev limit is 9500 revs,all controlled with Autronic Ecu and CDI unit
i would think it is making something between 850 and 1000 ps
All the std 4wd system has been removed from the car it now has a
mechanical system in place for the 4wd.
the car runs on 16" M/T slicks
thanks Keith
Keith like all forms of motorsport at the pointy end, it's going to require some serious tuning (suspension, tyre pressure, engine, etc) to get this working the way you want.
I really don't know of any meaningful advice many people on this forum can give you as not many of us run 800ps+ GTRs on slick tyres.
Mario Tobrac (not sure on spelling), www.exvitermini.com is one that has trodden this path and it took a LOT of work on the car setup to get his car runing straight and getting good times. I don't think there will be a magical fix that will cure this problem, just got to keep tweaking the car till it improves. Maybe send Mario and email through his site. He may be able/willing to help you out.
Good luck.
G'day Keith, from my perspective, it's a by-product of the Cusco front diff centre and the cross ply tyre your using.
Theo (a mate w-/ 9 sec GTR) experiences this now since installing a front 1 way locker. He installed this diff when the car started turning the front tyres alternately at high MPH under load.
He says it was even worse when he tried a "traditional" drag tyre as well. A stickier tyre will increase the effect of axle wind up due to unequel length front drive shafts. It was enough to touch the wall in fact! (He normally runs off the shelf Federal street tyres). Apparently he now has to release the power and straighten it up during a run.
Feel free to contact him, he'd be stoked to talk to you. [email protected]
Great looking car mate. All the best with it! :)
Great looking car mate. All the best with it! :cheers:
Hi Marlin
Thanks for the help,i was on the phone to Theo a few hours
ago he told me the same thing about the diff.
Keith
oh fark, I have a 'yet to be run' 1.5 cusco rs front diff !so what front diff is best ?
Maybe a stonger set of billet drive shafts for the front will minimise the wind-up? If you have got huge power, your gonna need something in the diff aren't you!
I've heard good things about the handling transformation on a circuit with these diffs. Are you a straights or a corners man?
Hi Dicky
My car runs OS Giken transmission parts
6 speed sequential box,front and rear diffs and a 4 plate clutch
Keith
Keith, you still haven't told us what times and MPH your car runs ;)
Beautiful car you've got there. Do you have any interior shots?
I have not done a full 1/4 mile run in the car yet
that is the big problem I have.
When we were mapping the car we were going from 30 mph / 50km to
over 200 mph / 300km in a distance of only 800m
Keith
http://www.croydonautosports.com.au/ they have the third fastest GTR in the world and have used a 6 speed sequential box before changing to an air change box. also willall racing have australias fasts street tyred car if your still using those nitto's dont know there number maybe some else will post up for u.
With a 1.5 way front diff, you might just need to back off the front bias once you get past 2nd gear ( I know things are a bit busy about then) but the torque steer is the problem & no way around it with that much power. i am a bit out of touch 'cause I haven't run my race GTR for nearly 2 years, but I remember crossing the traps at 153 mph with a 1/4 turn of steering lock to keep it straight so I understand the problem.
i am looking at going to slicks with my new setup, so will probably face the same problem.
All I can suggest is put more power to the rear & steer the thing at the traps the best you can. Welcome to fast GTRs. Never seen a really fast run that wasn't all over the track!!!
The HKS team told me to stiffen up the rear suspension & keep the car as flat as you can.
They have much less weight to deal with then us (mine around 1270 kg), so direction changes not as hard to deal with. Smoother gear changes will also help keep it straighter.
Easier said then done I know!!!
Keep up the good work, ultimately it's the testing that will give you the best results.
We are only just starting out.
Hi Munro
Thanks for the info on the diff.
When are you going to be running your car next
Keith
    • @soviet_merlin Thanks mate!  Nothing too major but will hold me up for a while. I've got lymphomas to get taken off the back of my neck and the middle of my spine which always conjures scary thoughts!  It sounds worse than it is. Yeah great, conjuring more rabbit hole deepening , just what I need! 🤣
    • I'd argue the F50 kit I got is very good value. For ~2k I got the calipers (refurbed condition), adapters, pads, brake lines, rotors, and top hats. I think you'd be pretty hard to get Evo/GTR/350z brembos + the additional hardware for similar money. Used market for a pair of front calipers alone I've seen tend to run anywhere from $1500-2000 depending on condition.    That said, something like a GTR or 350z brembo is a lot easier to adapt to the Silvia.
    • Is there a significant price difference between the Evo/gtr/350z brembos vs the F50? Looks amazing.
    • I was actually being a tightarse at the time LOL... My OCD is tickling me into running a 2nd 8AN Teflon hose all the way down and removing the 2x OEM hardlines. My other side of my brain is telling me to run 2x hardlines front to back (also acts as a fuel cooler, so win win).
    • As I mentioned in an earlier post, I had some trouble with the Silvia's brakes dragging back in 2023. I managed to sort it out then, but the same problem came back to bite me late last year. Just take a look at the picture – I had a feeling the handbrake was acting up again, and I was right. Anyway, I'd been wanting to upgrade to bigger brakes for a while. Not that the Silvia's brakes were bad, but it was more of a "want" than a "need", you know? It was funny, though – at the time, I couldn't find any Evo Brembos, 350Z Brembos, or GTR Brembos for a decent price (of course, tons of them popped up online after I already bought my kit!). I ended up going with an F50 Brembo kit, which came with adapters, brake lines, 330mm rotors, and top hats. The F50 Brembo caliper was used in a few other cars too, like the FPV. I also decided this was the perfect opportunity to ditch the Silvia's ridiculous rear brakes and that awful handbrake (some of you were definitely right about that!). I picked up some R33 calipers and all the necessary bits – rear drums, backing plates, and new hardware to refurbish the calipers. Of course, it wouldn't be a project without a few hiccups. Turns out the brake master cylinder was playing up and basically (to put it simply) keeping the brakes engaged. I had it overhauled, and after some adjustments, everything was working again. The whole process took a while, as you can imagine. To top it off, the front right wheel bearings were shot and needed replacing too. This is a rare occasion where I'm posting an update while it's all still fresh! These pictures were taken just this afternoon.
