Hi everyone i am new here.
I want to ask if anyone has come up against the problem that I am experiencing
with my R32 GTR drag car.
when I run the car on the 1/4 mile it wants to change lanes,no matter how hard I try to hold it straight
it wants to pull me either into the wall or into the other lane ????.
It feels like the front steering is toeing out but it is not,it is set at one degree toe in
the car has OS Giken diffs front and rear,the car has HKS drag dampers not sure what springs are fitted
the rear runs with 1 degree positive camber and one degree toe in.
Here is some info on the car and a few photos if anyone is interested
Car weighs 1210 KG.
Cusco front adjustable tie rods.
HKS drag dampers with HKS top mounts.
Midori top front adjustable camber mounts.
Border hicas removal kit.
Midori rear beam location kit.
Cusco rear top adjustable camber rods.
Midori rear tie rods.
Hope someone can give me some ideas to try
thanks Keith
https://www.sau.com.au/forums/topic/65227-help-with-r32-gtr-drag-setup/
Keith, how much power is the car making? I'm guessing over 800ps? Also what tyres are you using, and is the ATTESSA system running as standard or are you using some kind of torque split controller?
BTW good effort on getting the car down to 1210kgs!
Hi mmmgtir
Not sure on what power it is making to be sure
It is a Trust 2.7 with 290 11.5mm Tomei cams,it runs at 2.5 bar boost with a pair of 3037S
turbos,rev limit is 9500 revs,all controlled with Autronic Ecu and CDI unit
i would think it is making something between 850 and 1000 ps
All the std 4wd system has been removed from the car it now has a
mechanical system in place for the 4wd.
the car runs on 16" M/T slicks
thanks Keith
Keith like all forms of motorsport at the pointy end, it's going to require some serious tuning (suspension, tyre pressure, engine, etc) to get this working the way you want.
I really don't know of any meaningful advice many people on this forum can give you as not many of us run 800ps+ GTRs on slick tyres.
Mario Tobrac (not sure on spelling), www.exvitermini.com is one that has trodden this path and it took a LOT of work on the car setup to get his car runing straight and getting good times. I don't think there will be a magical fix that will cure this problem, just got to keep tweaking the car till it improves. Maybe send Mario and email through his site. He may be able/willing to help you out.
Good luck.
G'day Keith, from my perspective, it's a by-product of the Cusco front diff centre and the cross ply tyre your using.
Theo (a mate w-/ 9 sec GTR) experiences this now since installing a front 1 way locker. He installed this diff when the car started turning the front tyres alternately at high MPH under load.
He says it was even worse when he tried a "traditional" drag tyre as well. A stickier tyre will increase the effect of axle wind up due to unequel length front drive shafts. It was enough to touch the wall in fact! (He normally runs off the shelf Federal street tyres). Apparently he now has to release the power and straighten it up during a run.
Feel free to contact him, he'd be stoked to talk to you. [email protected]
Great looking car mate. All the best with it! :)
Great looking car mate. All the best with it! :cheers:
Hi Marlin
Thanks for the help,i was on the phone to Theo a few hours
ago he told me the same thing about the diff.
Keith
oh fark, I have a 'yet to be run' 1.5 cusco rs front diff !so what front diff is best ?
Maybe a stonger set of billet drive shafts for the front will minimise the wind-up? If you have got huge power, your gonna need something in the diff aren't you!
I've heard good things about the handling transformation on a circuit with these diffs. Are you a straights or a corners man?
Hi Dicky
My car runs OS Giken transmission parts
6 speed sequential box,front and rear diffs and a 4 plate clutch
Keith
Keith, you still haven't told us what times and MPH your car runs ;)
Beautiful car you've got there. Do you have any interior shots?
I have not done a full 1/4 mile run in the car yet
that is the big problem I have.
When we were mapping the car we were going from 30 mph / 50km to
over 200 mph / 300km in a distance of only 800m
Keith
http://www.croydonautosports.com.au/ they have the third fastest GTR in the world and have used a 6 speed sequential box before changing to an air change box. also willall racing have australias fasts street tyred car if your still using those nitto's dont know there number maybe some else will post up for u.
With a 1.5 way front diff, you might just need to back off the front bias once you get past 2nd gear ( I know things are a bit busy about then) but the torque steer is the problem & no way around it with that much power. i am a bit out of touch 'cause I haven't run my race GTR for nearly 2 years, but I remember crossing the traps at 153 mph with a 1/4 turn of steering lock to keep it straight so I understand the problem.
i am looking at going to slicks with my new setup, so will probably face the same problem.
All I can suggest is put more power to the rear & steer the thing at the traps the best you can. Welcome to fast GTRs. Never seen a really fast run that wasn't all over the track!!!
The HKS team told me to stiffen up the rear suspension & keep the car as flat as you can.
They have much less weight to deal with then us (mine around 1270 kg), so direction changes not as hard to deal with. Smoother gear changes will also help keep it straighter.
Easier said then done I know!!!
Keep up the good work, ultimately it's the testing that will give you the best results.
We are only just starting out.
Hi Munro
Thanks for the info on the diff.
When are you going to be running your car next
Keith
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
    • 100% accurate!  We are a pack of know it alls....  But, I bet people go to you when they have a problem! I've been on a bit of a clean up rampage too over the past month!  I've thrown more shit in the bin over the past 2 weeks than I have in the past 3 years combined! Anyway, it's all good fun being different! My wife sometimes does not agree!
    • ADHD in all form isn't about "can focus, or can't focus" or is hyper active or isn't etc.   It's all a dysregulation. Either time feels to be stationary, or time just vanishes in a split second. We are either under focussed on the task at hand (as we're over focussed on our surroundings) or we have no idea an atomic bomb went off beside us as we're so hyper focussed and locked in on things.   Not to mention the rapid fire thought process. What it takes a "normal" process to think up a solution to a problem, ADHD will be able to give you 5 different ways to solve the problem, and the pros and cons of each. While we can be highly impulsive and lack the ability to "control ourselves" we can also become paralysed with the inability to make a decision for ourselves. While most of us have an OCD like requirement for perfection, we lack the ability often to remain focussed to get things to a perfect state. Those with undiagnosed ADHD as adults, can often find the last part actually stops them ever attempting to do things that they have the ability to do, as the reasoning is often "if I can't do it perfectly, it's not worth doing"   As for projects... Ha ha ha, I still need to take the other half of my wall trim down in the Fiance's office so I can paint it. Need to finish digging and running the back yard drains, my R33, getting the Ninja bike registered (now being sold), the moped project, fixing either of the lawn mowers so they're reliable, along with a myriad of other things.   It's why I've been going through lately and just being brutal and clearing projects off that I won't actually ever complete. IE, moped will go to the tip, or be given away, bike is being sold, Subaru project being sold, some parts for other projects given away. Or I've been making myself focus on one thing at a time, by ticking off the smallest quickest ones first.   There's also a reason by our mid twenties we seem to be "know it alls", as we've all been down some of the weirdest and oddest rabbit holes when you follow the dopamine trail. It's often also why we're more a jack of all trades, but not a master of one.   However, pretty much all of my hobby projects, in one way or another, all come back around to automotive. That's my zen area.
