Keith, you still haven't told us what times and MPH your car runs :)
Beautiful car you've got there. Do you have any interior shots?
Hi NXTIME
Sorry i missed your post,i dont have any interior shots
I will have to take some,here is a few more photos.
Keith
Hi Keith (sorry, been offline for a while)
My race GTR will be a while still - probably late in the year.
Talking to Keir recently after his first runs on slicks & he was having problems
with tyre diameter differences due to growth during the run.
As there are only a handful of guys in the world pushing into low times it really
becomes a case of trial & error - just keep testing.
My suggestion would be try a set of radial tyres first (just to get some full passes
done & get some baseline runs) then put the slicks back on with a reduced tune
& creep up on it till you are used to steering it the whole length of the track under
full power - I am sure all of the fast Jap teams have done hundreds of runs in testing
before they found the best combination for each car.
From what I have seen the R32 is the least stable of the breed - so have fun!!!
I love Scotland (haven't been since 2000), wish I was there & you had a passenger
seat in it - would love to go for a few test runs with you........
Hi Munro
We took the slicks off and put on a set of street radial tyres
the car was just as bad.
I think the car is sitting a bit to high and when it is on full power we
are getting bump steer at the back end.
the car is fitted with HKS drag dampers with 5K springs on the front
and 4K on the rear.
we also have 1 degree + camber on the rear with 1 degree toe in
on all 4 wheels.
I am going to try dropping the car down a bit then set all the angles
again then give it a try.
If you are ever in Scotland again give me a call
Keith
  • 4 weeks later...
With a 1.5 way front diff, you might just need to back off the front bias once you get past 2nd gear ( I know things are a bit busy about then) but the torque steer is the problem & no way around it with that much power. i am a bit out of touch 'cause I haven't run my race GTR for nearly 2 years, but I remember crossing the traps at 153 mph with a 1/4 turn of steering lock to keep it straight so I understand the problem.
i am looking at going to slicks with my new setup, so will probably face the same problem.
All I can suggest is put more power to the rear & steer the thing at the traps the best you can. Welcome to fast GTRs.  Never seen a really fast run that wasn't all over the track!!!
The HKS team told me to stiffen up the rear suspension & keep the car as flat as you can.
They have much less weight to deal with then us (mine around 1270 kg), so direction changes not as hard to deal with. Smoother gear changes will also help keep it straighter.
Easier said then done I know!!!
Keep up the good work, ultimately it's the testing that will give you the best results.
We are only just starting out.
I have an hks etc with drag adaptor, with this unit you can set it up to automatically reduce bias to front after a set distance.
Even the HKS race team told us they didnt know how to properly set up the etc & drag adapter!! We asked them & they just shook their heads & the translation was something
like " ahh.. we tried that but it not work for us... mainly for street car...so sorry"
My car has an Apexi Manual hydraulic setup (like a big handbrake) we can adjust the settings then I can release it during the run - havent really get it set up correctly yet.
Keith - have you tested again since?
maybe try a set of firmer rear springs... i was going to get the hks drag suspension also but have not worried as we ran 9.77 at 145 mph on street tyres and it went down the track straight as... got the usual gear front lsd and a really tight rear lsd.. and fairly stiff gab coilovers...
but it may be different with your car being about 200kgs lighter.... dont know..
best of luck anyway.
Thanks judd.
Keith, didn't you used to have a twin 2835 set up that ran a best of 9.95 a couple of years back?
Hi NXTIME
Yes that was me,the car had a HKS 6sp dogbox then and had a pair of 2835
turbos running at 2 bar boost 750/800 bhp,on full road tyres.
the car now has about 250/300 bhp more than before and is now about 1200 kg
Keith
Judd you forgot to add the pfitzner box that the black Lancer broke aswell
no i didnt, at first i was told it was the gearbox but apparently it was a drive shaft which spilt oil over the track.so the pfitzner lives on...great box from what I have heard/seen soo far :D will wait and see.
keith, what box are you using now?
Anyone every thought to use an auto box?
i have but finding a 4wd auto box is another story, and someone to build it.
it was going to cost ~$4-5k any way, so decided it was either a os cross mission or pfitzner...and after speaking to Simon @ PPGearbox, my mind was pretty set.
looking forward to giving there box a try.
    • You've just discovered a really good reason to tell yourself, yes, I do need to buy an aftermarket ECU. Put the MAF in the bin. Slap in the new ECU and have a think about what turbo sounds you prefer.  Do you want a 90's style BOV wooosh? Do you want a hektik tsututututu?  Mate, can't go wrong. Just gotta get that ECU and the world is your oyster.
    • Hi. Iam just curisou about this topic. I saw this video. It is about Greddy Type FV2. I know that BoVs are about that sound but how and when to use it? I read some topic here and from what i have understand on stock RB with MAF there will be some "problems" if you use this BoV? It vents the air in to the atmosphere and the MAF on stock car needs this air back in to the intake and not out? Or is it wrong? If so...i saw you can put some adaptor to circule air back...but does that not "loose" that sound? I saw another BoV from Turbosmart and it has two "exhaust" like ports? One is for the stock tubing for letting air back and one is for "sound" and let the air in the atmosphere? Can someone please explain? This is the Greddy one:  And this is the Turbosmart.     THANK YOU!! EDIT: So i read about this topic some more and i if i understand that correctly: That Greddy can function either like BoV or 100% Bypass valve? And that Turbosmart is what they called hybrid so you can adjust what and how many air can be vented out or back in? Is this right? THX!
    • That dirty voltage drop is the culprit I suspect
    • i cant get them all in 1 screenshot unfortunately as i just dont know how to move things around tbh, but they are all from the same log and the line crosses at the same point for all of them
    • It's about time I start work on my sun tan. So I knocked up a few parts that will all combine together to become my new power steering reservoir. Now just to produce an abundance of UV and IR rays while melting a heap of bits of alu to become one... Well, that's after I put one more hole in it for the return line to plumb to. It likely won't be this weekend, as Sunday I'm meant to be in doing some last minute stuff to the AMG race car, and the weekend after will be filled with non my Skyline stuff, followed by Bathurst 6 hour. So I don't expect to get to melt metal for at least 3 weeks.   I also managed to stuff up and start cutting the hole for the res to pump pipe on the wrong side of the line... It means instead of the lines being nice and tight against the inner guard, they'll be out off the guard.    The size of it means I should end up with about 1.8L of power steering fluid, and still have space for another half a litre before it reaches the overflow/breather. This is wayyyyyyy more capacity than factory, which should help keep Powersteer oil temps lower, and the design hopefully allows it to prevent any aerated oil being able to makes its way down to the bottom as it'll have a couple of baffles and some hopeful trickery to force air bubbles away from the bottom.
