  • Replies 66
Go ahead with the 5 stud conversion if the turbo isnt coming for sometime. When u change it to 5 studs make sure u keep everything so u can change it back to 4 stud when you sell it, that way not all is lost in ur efforts and $.
Would recommend selling the gts and buying a t alot less hassles.
Could have been me - was it a chick driving or a dude with dreds???
A chick driving and a blonde chick in the passenger seat...
I new it was N/A by the wheel size and the blue GT badge on the side...you were still giving it what for though...
I was being tame I only just got my engine rebuilt...
what bootlid spoiler?? :confused:
car is 100% bog stock :)
my car cost me the price of a gtst - and i chose the na.
chrome rims.... hhmm... its a tough one some people can pull it off some cant just have to
see what it looks like when it goes on the car
You CHOSE N/A.....
You can always paint a car for alot less than you can do an engine conversion....
No offense but I have experienced the pain of many engine transplants...and not just my own...
i bought the car for a number of reasons; i am the first owner in australia, the engine is very
very healthy, the car was bought completely stock, the body is in good condition, and i simply
cannot afford the insurance required to pay at my age.
and simply - i really have no need for a turbo car...
well if i do decide to perform an engine conversion it will definately not be soon - during that time i may not even have the car anymore.
btw - i have found the RB25DE to be pretty reliable - just check all the problems in the forced induction thread and the ones in the natural aspiration :D:D:D
increasing boost, etc etc etc
Nah wasnt me - I'm in a series 1 and I havnt been driving any blond chicks around!! I would have been giving it what for though!! Actually got upto 175 ks on the way to the Sunny coast once - my fastest speed!
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
