Hi, anyone interested in a meet-up to go out to the drags on Saturday either meet at my place (if you know me & where I live) at 9:30am, or near the new Hungry Jacks at Ingle Farm Shopping Centre at 9:45am. Racing is 'supposed' to start at 10am, but NEVER does - so if we leave Ingle Farm at 10am we should be there for the start of racing.
Who's interested? Any objections to the time?
Andrew
  • Replies 76
yep cnr Walkleys and Montague Rds
Does anyone know what time the drags finish? I am actually thinking if the finals go well into the night, then maybe we do want to go early afternoon - I don't really want to be there for 12 hours solid!
yeah went well into the night the last few years.
i would be there for 12hours, but am more than happy if guys want to hang around for me and mel to meet up before heading out.
I don't mind missing some of the earlier action if it means a bit more snooze time on Sat morn! :( But i dunno how packed it gets, when it gets packed out at Calder you have to walk a country mile and leave your car in what amounts to a paddock, is it worth getting there early for a decent car park?
Guest Miss_Nismo
...and erica, we are going as a threesome, so if you can all meet up say at 2.30 pm then us three can join in. 9.30 am is way too early, i think last year it went until 9 pm??? Am i right?
Timmmayyy where did you get your express tickets from? I want in.
We'll be good, promise, no drinking from me... i'll spare myself the public embarrassment. :Oops:
Im glad its not 40 degrees this year and that its not valentines day either. Should be good weather for racing..
I entered last year and recall being at the track by 10am, running my last pass after 10:30pm and driving home near midnight! In the mid/high 40'c heat it was a killer :( Lost 4kg.
I'm not going to run this year (as opposed to my earlier intention to do so) but I'm keen to head out for a look. I don't mind going early or late... the only thing with going late is that we "might" miss out on seeing some cars if they have terminal failures early on. After my efforts last year 12hrs of spectating will be a walk in the park ;)
EDIT: Just checked the weather on the BOM site... it's looking good!
Friday : Min 15 Max 26 Fine. Mostly sunny.
Saturday : Min 14 Max 28 Fine. Mostly sunny.
ok new plan:
Those that know me meet at my place whenever they like before 2:15pm (will do a bbq lunch if people are interested), others meet at Hungry Jacks Ingle Farm cnr Montague and Walkley Rds 2:30pm. If you don't know me and want to come to an improptu SAU lunch, PM me and I will assess you on an individual basis - bringing bikini-clad chicky's to jump in the spa earns you browny points ;)
Is everyone ok with THIS plan?
    • The answer is to get a hold of the wiring diagram, work out what voltage is supposed to be where, when, and then work out why it is not there, then. I can't speak to the HR34 stuff, because I have never paid any attention to the NAs. There is a possibility that the turbo diagram will help, but it could also be different - depending on whether there is an FPCM on the NAs.
    • Hey guys. New here. I am having an issue with my hr34. The fuel pump isn't turning on. I removed it from the tank. Bench test it. Wasn't working. Order new one and installed it today. Still not turning on. Checked the relay. Relay has voltage on the contact side. I jumped it and it tuned the pump on. Which lead me to checked the coil voltage.  Turned on the ignition and had my meter across the coil and there wasn't any dc voltage. Had my meter lead on the positive and I used the frame ground and noticed there was 12 volts. Which lead me to believe the relay isn't getting a negative signal. I traced the wire ( black with pink strip).it goes back to the bottom on the steering and it gets lost into the harness.   I checked at the ecm and I can't seem to find that wire color.   My question if any one knows is. Can I not just run the negative through a ignition relay to turn on the fuel pump relay?. Or anyone ever had this issue and if so how did u go about fixing it.
    • So many people don't notice it, as batteries decay slowly over time. Two big reasons people end up noticing and needing to replace batteries: 1) The cold weather. The cold not only makes it harder to turn the engine for a few reasons, but it also increases the batteries internal resistance. So this means you need MORE power to turn a colder engine, AND the battery has a lower limit on how much current it can provide. 2) Something gets modified/altered/added in the wiring, typically an aftermarket accessory, like a dash camera, or an alarm etc, and this adds a small amount extra onto the battery, and pushes it over the edge in its failing days. But if you hadn't have read this thread, and just pushed through, chances are you might have made it through this winter, just. But come next winter, it would have been kapoot. But the fact you changed it out now, means you've instantly noticed how much nicer it is for starting, and will be less worry for you that the engine won't start now.
    • Holy shit, I'm glad you brought up the battery issue and I'm glad I asked about measuring it. Old battery was at a healthy 12.82V in the morning with the car turned off. Removed the fuel pump fuse, clamped the multimeter on at min/max/average and cranked for ~3 seconds. It dropped down to 8.30V. So yeah, not surprising it struggled that much. Picked up a fresh battery from supercheap and it's ridiculous. Haven't done a cold start yet, but man, even with a warm start the difference is night and day. I can't believe I lived with this for so long. Just blamed it on it being an old modified car. Went with Century because convenient. If they are shit it'll be a future me problem. But just in case I set up a reminder for 30 months - 8 weeks to check on the battery state and get a warranty replacement if necessary.
