One of my mates is trying to get a 300ZX complied but has been told that unless it's 15 years old, the car will have to be re-imported or destroyed. I don't know the complexities of it, but he needs to know the month and year the car was made. Since it hasn't passed compliance there is no plate on it.
Is there a way to tell the build date? I've heard of people using the Nissan FAST software, would it be possible to find the build date using this software? If so, PLEASE PM ME and i will give you the details needed. Otherwise, any other help would be GREATLY appreciated! Cheers guys, hope someone can help out.
:cheers:
https://www.sau.com.au/forums/topic/65316-300zx-woes-urgent-help-needed/
The build month would have needed to be confirmed in order for the car to be granted import approval under the 15 year rule. If your friend has gone ahead and imported the car before import approval was obtained then hes in a spot of bother.
Sounds fishy to me
It sounds a bit suss to me too, as my mate is buying it off a private seller who imported it himself. Anyhow, i will get the VIN number and see how things go. Luckily he's under no obligation to buy the car should things not work out. Cheers guys and gals.
PM me the chassis no. and I will let you know. ;)
Sounds fishy to me
This is correct, if he was importing it under the 15 year rule, then he should have an import approval and he'll be right. If he doesn't have an import approval and the government knows his car is here it will have to be crushed or sent back to Japan. My brother's first import (an 87 Soarer) came in before the import approval arrived, but the authorities didn't know it was here, fortunately the approval came the next day and everything worked out fine. I think this is why Prestige now wait for approval before shipping rather than just assuming it will arrive before the car does.
  • 3 weeks later...
    • Whoa, that's a name I've not see for a long time! Sorry to hear about the engine / turbo damage.  Fwiw with any engine problems it often really a case of just seeing what happens when it's apart, ymmv - I wouldn't rule out the possibility that the damage isn't even from the turbo failure, or possibly from a combination.  The airflow between cylinders isn't dead even, injectors can go off over time as well, with the turbos overboosting if you didn't have upgraded fuel system there could have possibly been a bit of leaning out - stock triggering is often a bit unreliable by this age too.  Basically its an old engine and a few things could have been going on, and you won't know how much work is needed until the engine is apart.
    • I'm just shocked there's a euro driver on our roads who is thinking of other road users and not attempting to blind everyone. I wonder if Prank uses his indicator too...
    • Its hard to tell really. The Q50 owner's forum talks about it a lot and has quite a few people directly affected, but no idea what % of cars sold actually had the block replaced. Also, there seem to be 2 distinct issues which both get diagnosed by Infiniti as requiring a block replacement (no wonder they are going broke) 1. "Porous block" where coolant mixes with oil through thin or poorly cast parts of the block 2. Head coolant gallery plugs not sealing. If I was noticing engine coolant loss I'd start with cooling system pressure test (as always) and then I'd pull the cam covers and reseal the coolant gallery plugs on both side before worrying about a potentially porous block.  If neither of those did the trick it would be put in a second hand engine out of japan; I haven't checked pricing but I'm sure there are plenty around by now as they've been in production 10+ years
    • To clarify what I posted above, I thought you both had a situation where it cancelled sooner one way than the other.....if it is reasonably even where it cancels in either direction that is probably normal (consider gentle movements like lane changes, you don't want it to need half a turn of lock to turn the indicators off)
    • Son, in this country, that is a piece of Gyprock. f**king drywall. FFS! I also like the autocorrect of trailer to tablet. I was reading it and thing, "what the hell drugs is he on?" Then the photo made it clear enough.
