Nugget_GTR Posted February 21, 2005 Share Posted February 21, 2005 ive tried the car audio thread but i should have asked here first!! has anyone here put a stereo into a GTR R32 im looking for the easyest way to put a 2 gauge wire from the battery to the boot. i got some idea from when i asked this in the audio thread but the guy who is trying to help me has a GTS T and where he doesnt have things in the way i have plenty which makes it alot harder than he explained you can take a look at the thread Here any help would be great... or ideas Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/ Share on other sites More sharing options...
SkyGTRline Posted February 21, 2005 Share Posted February 21, 2005 hmmm.... well, i drilled another hole... your prob not interested in doin so... but in the GTST there aint too much room for much, as i spose the GTR would not be any better. Above the Acc pedal and to the right, i made a hole... works well, just have to protect the cable from the firewall, so it aint wear throu and touch your + onto the chassis.. Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221320 Share on other sites More sharing options...
GTRsean Posted February 21, 2005 Share Posted February 21, 2005 Been there done that. RHS of engine firewall behind the suspension tower is a triangular opening which is blocked with foam. You will need to undo two 10mm nuts that hold the vac booster reservior above the hole. Feed your wiring through the opening and stuff the foam back in there. Lay your cable down the side of you floor to the back. You have to pull out the rear seat and your plastic door sill protector. Hook it up and get the tunes cranking! Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221456 Share on other sites More sharing options...
Sinista32 Posted February 21, 2005 Share Posted February 21, 2005 Sean's spot on. If you want to see my set-up Scott come by Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221633 Share on other sites More sharing options...
race_snooze Posted February 21, 2005 Share Posted February 21, 2005 chassie rail Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221890 Share on other sites More sharing options...
Nugget_GTR Posted February 21, 2005 Author Share Posted February 21, 2005 Cool that would be great. is there anything under the dash that i will need to removed to access it cause the other night i could not see where the wire would come out if i was to put it through the triangle bit. i could push it down but where does it go. i have alot of padding stuff lining up under the dash so i am guessing it is covering it in some way but looks like too much effort to remove it... and i dont want to go cutting it untill i know exactly where to do so. Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221899 Share on other sites More sharing options...
race_snooze Posted February 22, 2005 Share Posted February 22, 2005 use a solid cable to push through first then attacth the cable you need and pull it through Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1221951 Share on other sites More sharing options...
GM_GTR Posted February 22, 2005 Share Posted February 22, 2005 that's what I did...I just used a bit of coathanger wire taped to the cable then I pushed it through the big rubber gromet, I went from underneath though Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1222268 Share on other sites More sharing options...
SupaFly Skyline Posted February 22, 2005 Share Posted February 22, 2005 that triangle bit goes into the wheel well, if your splash guards still there you wont see it, and it may be a bit hard to poke your wire through, but there is nothing in the way under the dash when it comes through Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1222540 Share on other sites More sharing options...
race_snooze Posted February 22, 2005 Share Posted February 22, 2005 I have a plastic version that you could use. aka the yellow snake Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1222621 Share on other sites More sharing options...
Nugget_GTR Posted February 22, 2005 Author Share Posted February 22, 2005 Ok have got the wire through fine now which is great thanx for everyones help!! now i call on you again...... i have been trying for the last hour to getthe back seat out and i am about to cut it out im so frustraited with it. i know it has two hooks but how the hell do i unhook them i have tried everything... i know it is simple it cant be any different than most back seats which i have taken my far share out. but god help me i cant get this one out and it is shitting me.. any pointers much appresiated im about to go loopy :headspin: if i didnt have 3k worth of stereo sitting idle in the garage i would not even bother Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1222981 Share on other sites More sharing options...
GM_GTR Posted February 22, 2005 Share Posted February 22, 2005 Hi Nugget_GTR, underneath the backseats there are two clips, to unhook the clips you just pull the front part of the seat UPWARDS and the'll come off, then you pull the seat forward which will unhook two latches from behind the seat, the part of the seat where you sit on should now come out... Now you should see a couple of screws holding the other part of the seat, simply undo these then pull the seat upwards and it will come off... let me know if you get stuck Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1223065 Share on other sites More sharing options...
SupaFly Skyline Posted February 23, 2005 Share Posted February 23, 2005 Also with the two clips at the front of the bottom of the seat, you may find it helps to push them backwards with a screw driver/wheel brace and pull up at the same time Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1224372 Share on other sites More sharing options...
race_snooze Posted February 23, 2005 Share Posted February 23, 2005 sledge hammer and oxy can fix every thing j/k Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1224419 Share on other sites More sharing options...
GM_GTR Posted February 23, 2005 Share Posted February 23, 2005 lol.. I almost resorted to this the first time I tried Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1224687 Share on other sites More sharing options...
Nugget_GTR Posted February 23, 2005 Author Share Posted February 23, 2005 sledge hammer and oxy can fix every thing j/k i am about to resort to this i can not get it out!!!!! :cuss: Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1225483 Share on other sites More sharing options...
SkyGTRline Posted February 24, 2005 Share Posted February 24, 2005 GTST might be diff... but with the clips, you pull them out wards (towards the front of the car) to black tabs... just pull. Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1225625 Share on other sites More sharing options...
Nugget_GTR Posted February 24, 2005 Author Share Posted February 24, 2005 Woohoo got the back seat off i just lifted it up as hard as i could and they popped out .... bout time... :bananaman just need to get the back part off now, i couldnt see the screws holding it down it pulls out wards so i guess i can just lift it up off the top of the parcel shelf?? Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1226554 Share on other sites More sharing options...
GM_GTR Posted February 24, 2005 Share Posted February 24, 2005 hahaha...good stuff.......yep that's right, if it's already loose then just pull upwards, there's just a couple of hooks holding it on Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1226567 Share on other sites More sharing options...
GTRsean Posted February 24, 2005 Share Posted February 24, 2005 Then to get the back seat back rest off you have two 10mm bolts at the bottom corners. Link to comment https://www.sau.com.au/forums/topic/65321-audio-question/#findComment-1226663 Share on other sites More sharing options...
