hey what do all you guys think of a warlock 7500 alarm and immobiliser system with keyless entry thingy in it??? is it very good, ie: does it do the job well....have been told that it is pretty damn good, and insurance's wont knock it back etc.....
brad
ps: didnt intro myself on sunday at calder cause i was with my mate who was being a d.ick and didnt want to jump the fence lol and come over to say hi..so i had to watch from afar, and from the fence next to all the lines after the BIG oil/rain break admiringt the GTR hmmmmmm
:D
https://www.sau.com.au/forums/topic/6533-alarm-system/
Try a Black Widow, Python or a Viper. I think these are recommended by insurance companies.
I had a warlock before on my previous car, and after awhile the buttons didn't work properly. Took it back to installer and was told that it was an inherrent fault and that the new ones should be alright.
https://www.sau.com.au/forums/topic/6533-alarm-system/#findComment-97601
depends what ur after... personally whatever u decide wont really matter cause if they want it they will get it but it should keep out the n00bs.
also try to keep from posting what alarm u got in ur car on any forum or board as im sure that they (being the ***tards that steal ppls cars) patrol these boards etc. dont want to hear of anyones car being stolen let alone someone from here.
just trying to look at for fellow members.
cheers,
Ni
https://www.sau.com.au/forums/topic/6533-alarm-system/#findComment-97605
well thanks guys, i was just searching around thats all at this stage anyways
shall keep this in mind, woul never actuall post what i have etc :)
hey nark were you the guy who didnt have a rear spoiler on his line at calder, and had his girlfriend( i would supose) there as well?
just wondering cause if so at least i know someones face lmao
brad
https://www.sau.com.au/forums/topic/6533-alarm-system/#findComment-98112
i did holler out a couple of times, hollered out ''nark'' but you didnt flinch, just prob didnt hear me
well always next time :) cant wait till next calder meet, we should try do it as a regular thing!!!
does anyone know what happened wth the trophies etc.. cause if there are trophies, if/when i do a run i am sure to get the slowest car lol
https://www.sau.com.au/forums/topic/6533-alarm-system/#findComment-98118
dont think that went thru...
sorry dude if i was in the car when u were yellin i had my stereo on :)
not really up for it on a regular basis but every now and then would be fun.
next time i will have my FMIC, maybe a T04 (depending on what prices mark can do for me) or R33 Turb and much more boost :D
https://www.sau.com.au/forums/topic/6533-alarm-system/#findComment-98124
    • I started with the above in my head too, and I might be reading / thinking about what they want wrong, which is why I complicated it a bit further. Purpose I'm seeing is for the corner indicator to be on with headlights, and then if the indicator turns on it can still flash. The relay part above I can see working as required, except in the case of headlight is on, and indicator is on. The change over relay you've wired in would get signal from the indicator, and as it flashes would give power to the globe from the indicator, but as it flashes off, power comes from the headlight, which would cause the indicator to be constantly on when headlight is on, even while indicator change over is flashing. That is unless we don't care if it flashes or not if the headlight is on? I guess that's an OP clarification.
    • HI, Ive got an r34 gtt sedan A/T. The instrument cluster went out and I replaced it with another A/T everything visually looks the same and all the gauges work now with the exception of the speedometer and odometer. The speedo will stay pinned at zero until I'm going about 55kmh and then it'll say Im going about 5kmh. my odometer seems to be tracking at about a 1/10 of what it should. If I go 1km it'll say I've only gone 0.01. Appreciate any and all help. Ive tried searching through the forums reddit and a local fb group. The only info I think I've found is that some cars didnt come equipped with TCS (mind is) and the clusters may be different between those? I've also installed a brand new VSS and no joy obviously. TIA.
    • what speedo healer did you use?
    • Certainly. It is probably broken under the wire style clamp. At least that one is easier to get at than the front one.   Sounds like it isn't a major leak, I'd start with backing off the the water feed and return banjos into the turbos half a turn then tightening properly. Hardlines can still crack over time, either in the tube (particularly when turbos are changed if the banjo is siezed in the the tube) or at the brazed joins between the lines and the banjo fittings. A coolant system pressure test will reveal all. BTW you'd be able to get a sump without exchange, it will just cost more as they will have to source another stock one for the next customer. If you want to address the sump a much better option is something like this https://www.hioctanedirect.com/hi-octane-racing-sump-extension-nissan-rb26 that you weld in locally (and add the oil return fittings at the same time)
    • Pretty sure you are thinking of the throwout bearing there (which you should change when you change your clutch), when they are worn they will get quieter if you put your foot on the clutch. An input shaft bearing is turning/noisy at all times.
