Does anyone know what would the maintenance cost would be on a regularly serviced BMW 318 from around the mid 1980s (84-89) model... Cars in particular interest were regularly serviced with log books, clocking about 200,000-225,000kms....
https://www.sau.com.au/forums/topic/65337-q-old-bmw-318s/
Heya,
Simple answer is not much.
Detailed answer is like any car it all depends on how it was / is looked after. If you are interested in doing it yourself then you NEED to get yourself a copy of the Robert Bentley service manual for the E30 ...
http://www.bmwe30.net/cgi-bin/datacgi/data...0&finalrecord=9
The engine is an M10 and was designed by Baron Alex von Falkenhausen BMW's premier engine designer. An interesting note is that the M10 was the same engine that went into the Brabham F2 car and made over 1000 HP... so if you want a block that can handle 1000HP then the M10 is for you :)
From 1990 onward the M42 was used and was carried over into the E36.
But back to servicing. There are not many serious known faults with the E30, the M10 is solid as a rock, BMW Thermostats can cause problems but at about $70 from a Dealer they are not overly expensive.
Coolant Temp Senders (standard BOSCH item) can cause problems but are easily fixed, and the standard radiator can block up.
On the later cars (M20's are prone for this) the Idle Control Valve can get stuck and cause a rough idle, but on an M10 thats not so much of a problem as it does not use Bosch Motronic DME ECU's but its precursor in K-JetTronic.
http://www.bmwworld.com/engines/m10.htm
Btw... If you are in Melbourne, a good friend of mine works at a BMW Dealership and completes servicing on the weekend, so if you want a fussy BMW trained tech to service your car let me know.
Cheers,
Aaron
https://www.sau.com.au/forums/topic/65337-q-old-bmw-318s/#findComment-1225369
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
