Thought I'd post in here, I'm having a think about possible moving to Tasmania down the line, probably had people ask this before, but whats it like down there? Currently in canberra. Is fuel more expensive? And I take it theres a few half decent import mechanics in hobart etc?
From what I heard as well the economy isn't going to bad either? I'm only just starting to think about it, but just after some info, I work in IT.
wow whoretowns busy in here lol :)
Good to see some interest in Tassie mate! It is a good place to live. The car scene is starting to liven up down here and the fuel is no more expensive than what you pay in ACT. If you work in IT, there is plenty around in your field but prob not as much coin compared to mainland prices. My mate works down the west coast as an IT guru at a mine site and he's on a good package. Come down for a cruise one weekend and check it out.
There is always the TasCommodores organised East Coast Cruise this weekend you could join in with.
Invited pretty much anybody along as long as they behave naturally.
When: Sunday 16th November
We will be meeting at the Campbell Town football oval (just north of town centre) at 10.30am in preparation for an 11.00am departure.
We will be heading east through Fingal and St Marys to St Helens where we will stop for lunch.
Then continue north through to Scottsdale and back to Launceston via the Sideling.
The cruise will entail approximately 280km and should take somewhere in the vicinity of 4 hours including the stop for lunch.
Was an absolute blast a couple of years ago in the Hatch. Not so much fun last year in the Adventra.
    • If you haven't bought the ECU yet, I would strongly consider buying a modern ECU. Yes it is very easy to setup and tune, however it is lacking many of the features of a modern ECU. The pro plug in is something like 10 or 12 years old now? Can't remember exactly but it is very dated now. In that time the Elite was released and now we have the Nexus platform.  I would strongly consider not buying the ECU that is 3 generations old now (especially as it isn't a cheap ECU!).
    • Im happy for it as long as it means reanult gets the boot
    • Sorry I should have been more clear with the previous post.  The block is a sanding block - picture something like this https://motorguard.com/product/motor-guard-bgr161-bgr16-1-rigid-psa-sanding-block-2-5-8-x-16/ The guide coat is the paint It's two separate things I was talking about, there is no "block guide coat".
    • Maybe more accurately, you aren't just dulling the existing paint, you are giving the new paint something to 'grab on to'. By sanding the existing paint, you're creating a bunch of pores for the new paint to hook on to.  You can lay new paint over existing paint without sanding it, might last a year or two then sad times. The paint will peal/flake off in huge chunks. By sanding it, the new paint is able to hang onto it and won't flake off.  Depends on the primer you are using. When you buy your paint, as the paint supplier what grit of sand paper to use before you lay down the primer.  Use whatever you like as a guide coat. Pick a colour that really stands out in contrast to the paint. So say your sanding/painting a currently white car, using a black guide coat would work well. You very lightly lay the black guide coat down, then as you sand the car with the large block, all the high spots and low spots will stand out as the black paint is sanded off (or isn't sanded off).  When you buy your paint, hit up your supplier for recommendations for what paint to use for a guide coat if you're unsure what would work well with your setup.
    • Cheers thanks for the help mate I’ll see how we go with that one
