  • 1 month later...
  • 4 months later...
Hi Guys!!
In Tassie this week as navigating in a Dirt Rally on Saturday "Styx Valley Rally" ..First time so scary as hell! :D
Just wanted to say you guys live in a gorgeous place..I have been staying up in Burnie this week place it's amazing, only let down is the lack of vodafone phone coverage LOL :laugh:
Heading down to Hobart today so cant wait to see the rest of Tas :D Will be out in Hobart Saturday night..check out the night life and have some fun after my massive day Naving. If anyone is out and about and wants to meet up My Number is 0404042532 would be cool to catch up with some Tassie SAUers! :)
Seen about 4 x GTR's so far around Burnie :) a
Jess xx
  • 1 month later...
  • 3 weeks later...
hey folks!
Im in the process of buying some wheels off a bloke called scott Chambers. (scottys13 on ns.com)
Am organising it all through NS.COM. but the site has been down the last few days, so i cant contact him.
If anybody knows him can u please please get him to call me or pm me through here.
my number is 0425 759 644.
ANy help would be excellent!!
  • 3 weeks later...
Domain hillclimb vids :P
3rd run i did when it was fully dry
2nd run crash, start corners were nice and dry , came a little too hot into water tower corner and car slid to the lift into the bank. only damage was back side skirt mount dislodged.
Better late than never Ian, besides you should get used to being late now you own a SR :)
oh low blow haha yeah ill take that on the chin not a fan of the old SR :)
Edited by ian_and1
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
