Yea they do look good. Surely there no difference in front gaurds except for GTR gaurds are wider yea? Looking at buying CF GTR grill, CF eyelids, and GTR indicators atm. Wasn't sure on clear indicators and not a fan of the smoked style. Grill should fit. I got GTR style CF bonnet with same nose as one in pic. Not GTS-t where nose dips between headlights.
EDIT: If you buy a gtr copy bar for a gtst you wont need the gtr guards but if you get a genuine gtr bar you will need the gtr guardsthumbsup.gif
Well actually , a factory gtr bar fits better than the fibreglass gtr-gtst copies that i've played with , the only issue i've ever had with factory gtr bars is that they stick about 1cm into the wheel arch which can be fixed with a little plastic welding . i've fitted 2 copies and both of them stuck under the headlights at each side from being too narrow , which is a c**t to fix properly
That 32 4d looks tuff , makes me want another one! :ph34r:
agreed. i got a gtr copy bar and its 30mm out and didnt even fit over reo bar.. was so annoyed and couldnt be f'd glassing it to fit so sold it
i contemplated 34 front ;) but thats not quite targa spec lol... personally, my old kit, Do luck kit is the best 32 kit ive ever seen.
Yea I have a GTR style cabron fibre vented bonnet and headlights say R32 GTR (doubt there any differenceto GTS-t).
Oh and Funz...I have a Do Luck kit :P
Front bar pretty drift spec and rest of kit pretty shabby so want to get another Do Luck kit. Dunno how I will go with allignment getting 4 door skirts and rear bar with GTR front bar if I get GTR gaurds.
Hey Guys!
Just thought ide get a little sentimental and congratulate you all on being good guys!
its refreshing to read these forums and finding everyone getting along, helping each other, not bitching about other people and businesses.
Boostcruising.com seems to be full of it!
im getting all teary and shit :' )
Good work :)
Ant.
    • Change the transmission fluid. I would try Motorcraft XT-M5-QS if you have it in your area for a reasonable price. Also, double check your clutch is fully disengaging. If you are not pushing the clutch pedal to the floor fully for every shift now is the time to start. Make sure the clutch is fully bled. The damper line requires two distinct bleed points to be purged of air or it will not disengage the clutch properly. If either hydraulic cylinders input or output are losing hydraulic pressure in their seals/leaking you can have problems like this. If you've ruled out everything else then the most likely explanation is the synchros are worn and you need to double clutch the shift or rebuild/replace the transmission. The transfer case is discontinued FYI so you may want to rebuild it while you're in there too. If the chain stretches past spec it can do a ton of damage.
    • You're selling the SS?! How much are you asking on it?
    • My answer would be, that depends. If it's something that can be grumpy to start, runs a bit rich, and is likely an expensive engine, then yes, I would. But there's a few reasons why. Sumps aren't really sealed, there is airways to them, so it is technically open to moisture. Secondly, if as mentioned it has been started, and it's a fuelled up, I'd dump it, as chances are, fuel is in the oil. Next to that comes, how much use had said oil seen before it was parked up. IE, how much carbon, and potentially fuel/water did get in there while it was being used, and has now been allowed to sit, and slowly come together? For the most part, if it's just been something like a road car, stock engine, nothing wild, f**king send it if it's not near oil change spec.
    • I forgot to say Mark, you know how if you lack sleep, we get Grumpy Mark? When I lack sleep I'm Grumpy Matt. We must be the GrumpMa's!
