Any of you people crossing the river for SAU Nationals?
126 days to go? I'm actually very tempted... Nice site too, hard to pull off a black but clean style :) but get rid of that view counter! so 1995 geocities :P Use GA or something if you actually want to find that kind of information :)
Accomm costs - totally in your control via the website widget. It was easier to do it that way.
Not 100% on costs yet. Going to probably have 2-3 package options. Stuff like DVD inclusion etc.
But a bare-bones pack... Trackday + Show'n'Shine, less than $200 without question. Just don't now how much less yet, and we making sure everyone gets heaps of track time so limited entry to justify people coming interstate and stuff.
Show'n'Shine is only like $5-$10 as just have to cover the security guard hire & other similar costs.
BUT there are BIG f**k off trophies for track day, show'n'shine etc. Its looking like trophies alone will be costing at least 3-4k, so it's not being done half hearted :D
All that will be put up later once classes are worked out (2-3 weels)
Accomm costs - totally in your control. It was easier to do it that way.
But a bare-bones pack... Trackday + Show'n'Shine, less than $200 without question. Just don't now how much yet.
Pretty sure I'd just be a spectator if I went, transporting the car over and whatnot isn't worth enough to me as my stock little R33 isn't really competitive :P Although you're not sure on prices, will there be a spectator entry fee?
wow, pretty sure there's a massive story behind that which I don't know...
Not really a massive story just over imports and back appreciating the "older" cars again. I lunched 2 engines in my old 32 and it was off the road for nearly 4 years due to other commitments so I was glad to see the tail lights pull out of the drive when it left :D
    • MR HAMMER has said his piece. Painted up to avoid Rusty Rusty. Actually lines up well. (i.e it lines up the same as the unmolested GTR guard). Turns out the GTR Strut brace does foul on the bonnet vents ever so slightly. May need a little bendy bendy if intended to keep using with a strut brace. So spacing it out to clear the FAST102 is not an option. Annoyingly, the bonnet vents also foul on the heater lines running over the engine. Given this engine does not EVER require a heater, a delete loop is going to be used. Don't worry, the defogger uses the AC. The heater is basically "Do not use the aircon and turn the fan on". It will still be effective, I promise.... once I get the system regassed... Will have to revisit with unvented bonnet I suppose, and suitable strut brace. There's plans to do this and other things tonight and bleed brakes (there was a weep) and put the bumper back on, and take Good Friday morning - Because troubleshooting on the side of the road limping it home at midnight tonight is ... not very smart.
    • Thank you all for you assistance. I contacted Nistune regarding the support for the RB20DE along with my ECU Code (23710-10U00). They do have a map for it and added the RB20DE as a purchasable option now as well. They also added Malta as a Billing and Delivery options as this was missing. I was honestly amazed at their quick response and action, it took less than 24 hours. I also looked again at direct fit options for injectors, just in case I were to replace them. DeatschWerks seem to use a Bosch EV14 base and makes ones that fit mine at 440cc lowest, but also have 550cc at the same price. I tried looking for other direct fit options and managed to find one (also Bosch EV14 based) which includes a plug and play adapter on ebay. Did a small test with a Noid Light on the troubled injectors and all seems good, so they are pulsing properly electrically. One weird part is that they are missing on the same two cylinders as before I got the injectors cleaned. Mechanic also found this weird as he did not label the injectors and it is unlikely to have the faulty injectors be installed in the same cylinders.
    • Nice, let me know how you find the 98 tune
    • Put a hand on an injector and see if that's what the buzzing is. You might be triggering the injectors by moving off idle command.
    • Ah, should have been clearer. Currently has a flex sensor installed all good to go.    like u mentioned, I’ve only ever known the car on e85, I might hate 98, but I have to try it out first. Everyone says the -5 turbos get pretty laggy on 98 octane tho…
