my power fc is locked/password protected whatever, would a tuner be able to unlock it does anyone know?
You need a Datalogit to unlock it. Yes a tuner might be able to unlock it if they've got the smarts.
never seen a 'kit' before mate , most people use stereo (0 or 4 guage) cable (there is probably better cable you can use? ) , and run it from wherever the + battery terminal under the bonnet leads to, then earth to the body somewhere in the boot then buy a marine battery box and house the battery in that :) (just remember the battery has to vent outside the car to be road legal)
Edited by toffy
Thanks guys.
Haha I'm the sort of person that whenever I play electician, I leave the shed with tingles lol. I can do a little bit. Once I find where the +battery terminal leads to and mounts, I can run the cable and hook it up into the battery leads ok. How do you go about securing it in the boot so it doesn't roll around? Otherwise it not bolted down but it secure positioned in the footwell behind my drivers seat :laugh:
Most of the stuff you need you should be able to find at a campervan/trailer place or auto electrician joint will sell the parts.
You'll need the biggest cable you can afford (up to 0 gauge) 4ga as a minimum. Don't use car audio cable, use something with thicker strands in the windings.
6-7m of + cable
2m of - cable (must be the same size cable or bigger)
Insulated mountable terminal post
Crimp on ring terminals (once the cable is cut to length, get somone to crinp them on the cable for you)
Heatshrink (thick stuff with glue inside)
Battery terminals
Battery tray
Battery tie down
Battery box
Make shure you sand back to bare metal any earth points on the chassis. Any terminals on the cables have to be crimped on correctly. Try and consolidate the + feeds onto the + post in the engine bay.
Have fun
Justin
    • A little follow up here on the ceramic coating.  We've had storms galore here and I've done a few ks, enough to gross them up  Consensus is that they didn't get as dirty as usual, the coating definitely repelled a little of the dirt and I think they kinda snowball. They get a little dirty and then they get dirty faster which makes sense. Cleaning them regularly would allow them to protect better.  Cleaning was a breeze. I tried first to just hose them off which, unsurprisingly, did nothing. But, making the wheels wet and then just wiping them over with a used but clean microfibre cloth was all that was required. I didn't need any cleaner at all, just water and a cloth. The wheels look amazing again.
    • Gave her a nice wash today and took extra time to clean off the tree sap and tar and crap. We have a usable garage now so she'll stay cleaner longer. Took a few snaps in some nice light afterwards.
    • OK, solid mount Z1 diff brace is in, pretty straightforward, it picks up 3 diff hat bolts and ties them to 2 support bolts on the subframe. Pretty sure someone else on here said they had reduced axle tramp with this but mine was already pretty good for smooth wheelspin, and still is....will see you this goes over time and whether I end up with a broken rear diff hat
    • Ah yes, but the part in my hand was actually painted and fitted by me! I knew any front lip was likely to be sacrificial but I've had to fix it twice already... by the time I buy a fibreglass fixing kit, sort out sandpaper blocks, buy some fibreglass filler, body bog, spend the time and effort for a 'Greg' result... a new one being $290 seems like it's the better way to go and spray that with bedliner/raptor coat and we're all pretty again.. Would have preferred it last more than a month though. Them's the breaks I suppose.
    • I find it funny that the USA is finding out all this really really weird stuff, and people from the USA are coming here treating it like gospel, yet, all the info on solving those issues is here on these forums for the last 15 odd years... Also, I know how much heat it takes to ignite the hood lining of an R33 skyline. I worked it out myself... It also took a LOT of time, and heat for it to do it... Big single, and I needed to drive the car, so retarded the timing off to "protect it". Yeah, that was a bad move for cruising on a freeway with only 15 degrees of timing on it. That was a lesson I learned around 2009. So that's over 15 odd years ago. Aligning water and oil, that's identical for any turbo engine, it's not Japanese specific. If a shop doesn't know how to make sure the core is rotated the right way, then they shouldn't be touching any turbo engine. That's not a matter of "We haven't had Skylines for that long here"...
