yeah I fired it up a bit yesterday, Got stuck with some class one dickheads in the Mx5s; they were going hella slow around lime rock and because I didn't qualify I started from the back, trying to work my way through and they just would block me on the straight and just be assholes. I managed to get around most of them by driving in their blind spot for a few corners and then sneak past exiting the corner. Still managed to come 2nd :D
Had a go at oval too, figgured I suck at that, I was OK in the legends and manged to lead for a few laps but I'd just cook my tyres and run wide into the walls :(
The biggest and most enjoyable thing I found was getting out of the Rookie/Class D series, with maybe the exception of the Skip Barber, as that's a fun car to drive as long as the racing is clean. I'm happy they've made the Radical a class C car again with races going off every couple of hours, because the Radical is an awesome car to drive. It's one of the ones I can actually drive on the limit strangely, I can't do the same with most of the open wheelers... I seem better with tin tops like the Mustang etc. *shrug*
And yeah, jerks in the MX5 blocking is annoying.
  • 4 weeks later...
2 of my hoes' , one is the dirty broad minded person you thrash the f**k out of , the other is the good girl you take to meet mum and dad :) , both need a wash atm , but i just brought the 34 down to my work to pull the locks out to send away to get fixed :) , it hadn't seen the road in over a month? , and a blown 3rd gear 20 box (the first and only one i've blown so far) and the new dash i made for the hq and my new tow bus :)
    • Does your rb gearbox have the common input shaft bearing sound? (One one where it goes away when u push the clutch in or get to higher revs) I heard if you put the wrong oil it can get this sound.
    • There's more than one way to skin that cat, and most of the sump Maatouks have done will be GTR sumps. They are HUGE in GTR drag racing here.
    • Yeah...I always start at the shift solenoids, because there's only a few reasons these will spook into limp mode, and bad shift solenoids is one ~ the other can be the shift control module (if you have steering wheel shift buttons)...it's easier to eliminate the solenoids first.
    • Might piggy back off this thread since there's been a good discussion about PWM.   I purchased a Walbro 460 F90000267 and have been looking into PWM to understand it. It was purchased more of a future proof as my original OEM fuel pump died (r33 below 200kw) and figured I'd just upgrade it to this. That's when it hit me that a pump this big can cause more dramas with such high amperage draw and heating of the fuel pump being on 100% all the time in such a mild setup.   I have a Nexus R3 and slowly collecting power mods but I was looking into the PWM feature on the NSP software:   Then looking at the graph from the fuel pump:     Am I safe to assume reducing duty cycle to 50% for example would make the pump run like a 230/lph ? Where does the PWM come in all of this ?   I've gone down the rabbit hole of PWM fuel pumps and it seems there are many differing opinions on how to go about it 😅
    • Thank you, this will keep me busy for a bit.  I will update progression.
