what ever you want it to say.
"my other car is a shitter as well"
"i cant help it im ugly..."
"SPEEDING,  no officer its cause my feet dont reach the pedals"
You tell me
:P:)
Make it Boostless
and its done
playing with my broken car
im sick of doing that, i just get more piles of junk sitting next my car.....
what do i need to qualify to get on the dole for a few weeks so i can bum at home?
BWAHAHAHA
i hear that.
I was thinking more of a "work accident" and out on compo would be better :lol:
Edited by grandmasterb
fall off your chair while watching porn and strain several muscles? haha
Or maybe RSI??
Your boss fed you to much piss you need a week to recover? mind you he wouldn't be able to shout you for a week....
slowly haha, I have been slack. clutch got ordered today same as your's and matt's. And still sussing out rods. Belly pulled the stock turbo apart and said it's like new. Couple of oil rings had ceased, but on a bright note bore is standard and absolutely beautiful. Not going to estimate when it will be done cause then it'll take twice as long. But will definately be ready for semi-final in november. Loving driving an economical car atm too! soooo good.
Read somewhere you were thinking of selling(might have been on here) what you looking at getting? Something a bit cheaper to run and keep on the road? haha!
Yeah its time for a change there are too many R33s about so i am going to find something different, havent really deceided yet. I have had a few people ask about the engine and diff they want to swap for standard parts and give me cash. Then i would sell the car cheaper.
Paul just make sure belly doesn't accidentally put my engine in your car by accident, would hate for you to get more than you paid for! lol!
shit i should go get that thing one day, just got nowhere to put it till it goes in!
*looks for some undercover safe house*
dude if you can figure out how i can have a work place accident where i work and get away with it..... ill split 50/50
BWAHHAHAHA
yeah i know what you mean.
The RSI is the one i been thinking of the most, but then i dont know if i would get away with that at work either :unsure:
Or maybe RSI??
Couple of good suggestions there but i think they all come under the work place safe campain already.
They have expected little boys like TIMMAY to do something like that :lol:
    • They are what I will be installing. 640s for me.
    • Hmm... From my experience you get about 0.25° camber change per mm of RUCA length change. So, to correct from -2.5 up to less than -1° (or, more than -1° if you look at the world as a mathematician does) then you'd be making 6-8mm of length change on the RUCA. From a stock length of 308mm, that's 2-2.5% difference in RUCA length. My RUCAs are currently very close to stock length - certainly only 2-3mm different from stock. I had to adjust my tension arms by 6mm to minimise the bump steer. That's 6mm out of 210, which is 2.8%. That's a 2.8% change on those, compared to a <1% change on the RUCAs. So the stock geometry already has worse bump steer than is possible - you can improve it even if you don't change the RUCA length. If you lengthen the RUCAs at all, then you will definitely be adding bump steer. Again, with my car, I recently had an unpleasant amount of bump steer, stemming from a number of things that happened one after another without me having an opportunity to correct for them. I only had to change the tension arm lengths by 1mm to minimise the resulting bump steer. (Granted, I also had to dial out a lot of extra toe-in in the rear, and excessive rear toe-in will make bump steer behaviour worse). Relatively tiny little adjustments having been made - the car is now completely different. Was horrifying how much it wanted to steer from the rear on any significant single wheel bump/dip. And it was even bad on expansion joints on long sweepers on freeway entry/exits, which are notionally hitting both rear wheels at the same time. My point is, the crappy Nissan multilink is quite sensitive to these things (unlike the very nice Toyota suspension!). And I think 99.75% of Skyline owners are blissfully ignorant of what they are driving around on. Sadly, it is a non-trivial exercise to set up to measure and correct bump steer. I am happy to show my rig, which involves nasty chunks of wood bolted to the hub, mirrors, lasers, graph paper targets and other horrors. Just in case anyone wants to see how it is done. I'll just have to set it up to take the photos.
    • What do you have in that bad boy ? Ill go with the 725cc since I'll be going with Nistune ( would definitely like more engine protection but Haltech is too far out of reach at the moment... plus, Ill probably have a pretty safe tune as its a daily, not gonna be chasing peak power 24/7 ahahah ). Are Xspurt a safe choice?  Pete's great. He didnt mention anything about traction arm length so I reckon it may be good. When I get some new wheels/tire later down the road I'll ask him about it and get his opinion on em. I heard from Gary that you've got the bilsteins too, are you running the sway bars too? and what other suspension goodies do you have installed or would recommend?
    • In true Gregging style...
