hahaha sif
you need to show the others its ok to talk in the tassie section
:lol: yeah i know
but without there mummy's sitting there next to em they dont know how to spell.
If the wind changes direction then they are confused :(
Cheers dude.
I PM'd Christian again the other day and he 4got about our convo about it.
But its all sorted now and all good so i can help get TASSIE on the map :lol:
map-o-tas
