agreed GMB....they should ban extremely small penises like urs!
:) OK
It would be funny if it didn't come from a guy that is 20+ and can still get into the movies as a child.
You can insult me when you are over 5'5" and not a second sooner wee man :)
f**k u.
i save more money than u that means
also its my birthday today.
happy birthday to me.
Sweet 16 at last ;)
Happy birthday darlin.
Now you can sit at the big kids table at McDonalds (its ok we will let you use the high chair still so you can see)
You would save money if you would stop making those midget porno's that you have to film/direct/star in ;)
  • 1 month later...
  • 1 month later...
    • Not sure if this helps but I had a similar issue where one of the doors wouldn't lock unless I pressed the lock key twice. Turns out the door actuators were f**ked. In the Nissan service book it says to lube it every now and again, I guess put a bit a bit of wd-40. I replaced mine and haven't had a problem since.
    • 2 things. 1. If you're going to buy a ball joint puller/pusher tool that is not advertised as being for the purpose you intend to use it for, then it is up to you to make sure, either before you buy, or after you first try (and possibly fail) that it will work for that task. 2. WTF? Putting HICAS balljoints back into a car implies retaining HICAS, which is just....dumb. HICAS can lick my left one.
    • After cleaning the contacts in the remote, if it has rubber carbon pads on the buttons, give them a little wipe with a 2B pencil to add some fresh carbon back. Just a little wipe. Not too much.
    • The one door lock not working intermittently sounds odd. But for the other issues I'd suggest to clean the contacts and everything on the little board inside the fob. I had the same issue with unlock working but not lock, and that solved it. It brings such a quality of life change to be able to lock and unlock the car like a normal person
