he told me so....... wish i still had my rb ....but some low life kent stole it and torched it....... f**k U........ U WEAK ARSE KENTS (GMB remind me to lay off the drink on weekdays). CRY!!!!!!!
back to square for me...although my ca is pumping more hp's than most modded RB's (200+kw CA and 850kg AE86 for the win) lol......i miss the torque and sound.....CRY!
and the 4 doors...and my coilovers.......i need more beam cans hahahahahha
drink my sorrows!
new car in the new year!
R32 four door (sex on wheels).......or S13(just easy to come across)?
RB25DE+T in either......... opnions? (whore it up on this question)
(god im loving the brackets tonite)
its gunna be for the wife to wheel on Drift days....and me when my CA gets rebuilt every 3 weeks.
over and out
benny g unit.
Ha ah ha, you drunk!! :P
The Ae86 sounds the goods benny........ And you know you want another r32 4 door...Fark the S13's
(how much did the Carbon bonnet cost you on your old one? and where did you get it?)
cheers. Luke
Ha ah ha, you drunk!! :O
cheers. Luke
Luke
im pretty sure the bonnet on Bennys 4dr was off XRATED...
  • 3 weeks later...
deos anybody know if gtr cam covers fit a rb25det? hand to put a clear cover on the timing belt and dress the motor up a bit
No they dont. :yes::D:no:
There is a guy here on SAU that has had a mould made up to make the clear covers for the RB25, I think this is the website http://www.tracksideperformance.net/
cheers
Edited by woolls
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
