Dr Pepper!!!!!!!!!!!1
argh I havent had some for so long.. cant wait till I go overseas next month.. going to eat all the american food I miss so much
I buy it a carton of it every couple of weeks.
Man im addicted to that stuff :P
f**k f**k f**k f**k
I have to check and see if I got parked in by my boss in the carpark..
i have to go have a passport interview at 3pm and I wont be able to make it argh f**k
What does your boss drive???
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
