do you guys down douth have an weekly meets or places where you go on weekends?
I'm gonna be in lonnie from the 13 to around the 16th, might go to hobart for a day/night aswell...
good to catch up with a few interstate comrades.
  • 4 weeks later...
    • Well, the NC is just an RX8 anyway, right?
    • Now Mark, I know you've already done an engine swap, but how about doing an engine swap that reduces a lot of weight, and effectively makes it a mid mount engine setup?   https://youtu.be/A99702U07QI?feature=shared
    • Does anybody know the weight of the flywheel for the Nismo twinplate coppermix clutch kit for bnr34 over the standard flywheel? Is it a dualmass flywheel like oem or single mass?
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
