GTR turbo Kit (T51?)
Kit includes
Turbo (not entirely sure what it is Heres the INFO i have (When i bought it they said it was a T51 turbo)
HKS Turbo (guessing from the logo on the rear cover)
Garret Front Cover
HKS exhaust Housing
Compress wheel is 7cm across
Exhaust Wheel is 7cm across
A/R .72
Front compressor bell mouth 10cm across
Serial number on turbo - WG 7011J
Seems to be in Good condition
Thats all i have on the turbo
Heres what else it comes with
Dump pipe just over 1 metre in length
Twin air filter to Bell mouth Pipe
Intercooler pipe with Greddy adjustable Blowoff valve
Alloy shrouds (heat) 2 off for the Manifold etc
Exhuast manifold with pipe running off for External Gate
And what looks to be a alloy pipe about 50cm long looks like a External gate Dump pipe
Sunshine Coast QLD
0438145562
Welcome to come have a look!!!!
Only advertised here so far
Wish i could test it but i haven't got a GTR and wish i did
https://www.sau.com.au/forums/topic/65349-gtr-complete-turbo-kit-2200ono-hks/
