ok then please don't take this the wrong way, its the tune there is no other reason it would be pinging at higher boost
I was running 19psi through a stock motor, stock head gasket, stock compression take it back to Scott and tell him you want it tuned for 16psi as saying the comp is to high for more boost is crap, its just not tuned for it
Brett
  • Replies 115
I was running 14psi just front mount, exhaust and bleed valve... no pinging. Actually was running very rich.
I seen that thing, no way was it stock. You should have seen the brakes he had on it!!! Very nice car though.
I saw that white R34 GTR and when i talked to the guy i asked him what was done to the car and he told me that is has exhausts filters and a computer. i asked him if the turbos was done and he said no! THAT car does has 6 point pistion calipers and i dont know why u guys keeps sayin its standard that car sounded ****in nice aswell and it ran a 11.932 very fast aswell :ufo:
mmm bit suspicious..yes they are 4piston alcons with what looks like 355mm discs but when he was talking about them they some how grew another 2 pistons to 6.
they are fine brakes neither the less.
What did u have a tape measure there and u measure the brakes u guys seem to have no idea and if u were to actually talk to the guy he aint a liar!! Some one has to defend him cause everyone on this forum seems to have something to say about this very nice car and its fast aswell
GTR32X: I dont think anyone has a bad word to say about the guy, the car sounds phenominal. I think the point people are making is the car looks pretty serious and sounds fantastic, thus the questioning about how stock it actually is.
Either way who cares? I know several people who routinely say their car is stock when its far from it! :D
Mate is this the owner of BY BY well u have alot to say and someone has to defend him!!! Anyway why did i call u car UGLY cause i dont like R33 and if u wanna race lets GO!!!!!
What the fcuk? :D :D :) :)
I haven't laughed this hard for ages!!! How old are you mate? My 4 year old nephew exhibits more maturity than you ugh2.gif
man, I'll race you for sure. except we do it my way. we race for pinkslips and honor.
meet me tonight at Shinkjuku maccas, the one behind the altia building. I can't bring the GTR though so we race on foot.
if you don't turn up I can only assume that you are too chicken to race me.
no way I'm racing you roy. you told me your car was stock but when I checked it out I saw the autobarn air freshener stuck to your AC vent.
nice try though... bullsh1t artist!
Its isnt from Autobarn, i was going to get one of the Autobarn ones but Supercheap had it on special, turns out it was a Chinese imitation so in my eyes my car is still stock. Who are you calling a bullshit artist...you dont know me, you can talk to me like that...you aint my Daddy , are you:confused:
who's yo' daddy?
Hey buster u r ok! i like ur car its nice but BY BY has said some things to us that offended us so thats why!!! keep up the good work mate like u car
Care to elaborate?
Who is us? Perhaps if you actually tell us whats apparently been said and about whom then I might know what your talking about.
How about justifying your accusations by confirming what offensive comments I have apparently said about you/your friend etc.
:D
    • Also had a look at the Nissan JP website looks like the 400r has a slightly shorter ratio than than the regular V37 3.133 VS 2.937 which from a guy who has driven both 3.69 vs 4.11 ratios in the S15 is bugger all. Seems that the AUTO Z runs the same ratio as the 400R but can't find any info as to if its an open or LSD? More often than not the auto LSD is open
    • Do not replace the power steering lines with this stuff. If it's anything like the Chase Bays stuff it will leak and be worse than stock. The reason why the reservoir is on the LH/passenger side of the car is because that's just where the reservoir was most convenient to fit. Don't overthink this stuff. The intake/cold side of the engine is pretty busy on these cars. And again, the hardpipe is designed to be a janky power steering cooler. In theory you can replace it with a real power steering cooler but that's really only for track use where boiling the fluid is a distinct possibility. Start with the low pressure lines feeding the pump from the reservoir. Make sure there isn't a bunch of junk in the reservoir filter. Be careful to not get ATF all over the engine bay. I hate dealing with ATF spills, you can clean it up and the slightest crevice will still release more oil that can still drip over time. You also want to inspect for leaks before you make a mess and can't tell what happened. Most likely you have a leak somewhere that is allowing fluid out and air in. Failing that it's allowing air in but not fluid out. Only place I can really see that happening is on the low pressure side because the pump will pull a slight vacuum to draw fluid in. Everything after the pump is high pressure or lower pressure, approaching atmospheric by the time it returns to the reservoir.
    • I did a skidpan night at SMSP this week, it was much cheaper than $350. But yeah, you need to slap an LSD in that thing.  I put an OS Giken in the 370Z and it's f**king MARVELOUS even compared to Nissan's viscous LSD. So you're saying it's free now that it's a housing estate? 😂
    • Nah, the car seems to run exactly as it did prior, in saying this it does "seem" to be better down low, like more eager to rev, but that may be 100% placebo effect from intake noise But, I'm not worried about it at all, in the end it is a fairly low compression NA engine that has a well shrouded intake,  if it is getting hotter IAT I cannot notice anything negative performance wise from the seat of my pants thrashing it about on the street or sitting in traffic, so meh, car now now makes induction noise so I'm happy
    • Do you have an IAT sensor? It's worth checking it to see. You may be suprised how little gap you actually need to flood your engine with hot air. (I tape up my airbox for a reason) :p
