  • Replies 84
if its a 33 you dont need to take the front shaft out at all.
ask markr34gtr for the details, but when mine went on the dyno all he did was bleed the fluid from the in-tank boot for the attezza, and poped the plug from under the dash and ran rwd no probs basically. took maybe 5-10min and no hoist.
How do people dyno a GTR on a 2wd dyno? Do they take the front drive shaft off? If this is the case, wouldn't gear oil spill everywhere?
You don't take the shaft out, you just disconnect it. :boinkcar:
you unplug the 4wd fuses then crack the pressure out of the line that goes to the back of the transfer case.... as r33 and 34 have constant pressure to the transfer case so the 4wd sytstem is preloaded to some extent....
but you will have to bleed the 4wd system when your done on the dyno....
if you dont know how to do it dont risk it just go to a 4wd dyno.....
hope this helps...
Has anyone tried doing what the R33 Service manual says to do (see attached pic).
No. 1 says to unplug the air evac plug under the dash, turn the ignition on and pump the brakes 5 times with 10 seconds of turning the ignition on.
If you've done it right the 4wd light on the dash will flash twice every 1 second....
Might be easier than draining fluid and then bleeding the system when you've finished.
I'm going to try it on my Stagea to see if it works (not sure if it will, I think the ATTESSA is slightly different). I just need to work out which plug to disconnect cause the diagram isn't much help !!
J
OK, just spent the last hour outside having a play.
Looking under the dash I found one plug that had a single black wire going into it and a single yellow (with a stripe) coming out of it - see the attached pic.
I found the plug strapped to another wiring loom, and if the GTR's under dash is the same as the Stagea's, then just follow the hood realise cable and it's sitting right near it (you'll see it in the pic).
I thought it was strange that it was very accessible :rolleyes:
So I pulled the plug apart, started the car and pumped the brakes 5 times within 10 seconds and you wouldn't know it but the 4wd light started flashing twice for every second !!!
I suppose this will be safe to do seems that it's in the R33 service manual. It doesn't say anything about 'do not drive the car like this etc...', but it'll be good to try it out on some dirt or wet grass somewhere to see if only the rears spin.
Anyway, I thought this may help a few people so give it a try.
Anybody want to comment?
J
I thought it was strange that it was very accessible :D
J
Yep that works, only the rears spin, both of them too :D Taking it out to Willowbank 2nite to see which way I get the quicker times, judging by how easy it spins up the wheels I think 4WD will be quicker ;)
Wow, now that is good to hear.
Now I presume if there was some (any) torque going to the front wheels they would spin while up on the hoist and you had the backs spinning with throttle. Even the slightest bit of torque would make the fronts turn.....
Great news :P
J
  • 4 months later...
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
