in the engine bay there is a fuse you can take out marked 4wd fuse, or under your dash i think its the top left or top right one, you can try by removing thefuse while the car is on, it will bring up the 4wd light, negative aspect is you will destroy a lot of rubber ripping hellies.
  • Replies 84
hahaha glazed donuts!
i am told that you should take out the front driveshaft as to not damage the clutch pack. On street its fine cos the front wheels are in motion but on a 2wd dyno, the fronts are stationery.
There is a single power wire (according to the wiring diagram) that runs to the motor which pressurises the 4wd clutch pack. Putting this through a switch should provide an easy on/off. Unfortuantley last tme I just found the wire for the 4wd light....and have been too lazy to fix it. When I get it back I might try again.
  • 4 months later...
Guest DIRTgarage
At which end? The front diff (sump) or the transfer case? Isn't the flange on the front diff? If you disconnect there, won't the shaft turn and hit the bottom of the car?
Just remove the four bolts in the front of the shaft and lift it out....the socket it fits in is sealed from the transfer case...i.e. no oil/fluid will escape.
all too much effort removing front drive shaft...
just pull the 4wd fuse in the engine bay on a 32 gtr...
on 33 and 34 gtr s pull fuse and then crack the bleeder nipple on the transfer case to release the presure in the line which 33 & 34 s keep pressure in even when in 2wd mode.
hope this helps.
Yeah but all that means a pinch of poop to me as I am a noob at this whole "knowing mechanical parts" thing ;)
Just pulling a plug and pumping the brake is just about the limit of my minds ability :thumbsup:.
So question is which way is the correct way, Jay's pulling plug and pumping brake or Mark's pull fuse, crack bleeder nipple and release pressure?
And again with both methods, what is the correct proceedure for re-instating 4wd mode?
Thanks!
  • 1 month later...
Hiyas,
Just wanting to see if anyone had an update on the situation. Obviously the computer method sounds easiest but has anyone actually used it on the dyno?? any potential for damage, no chance of fronts engaging, etc?
Secondly just wondering if someone could step me through slowly the method to disconnect the front driveshaft (ie, raise on hoist, etc). Maybe deservers a FAQ.
Cheers,
Penfold
Just undo the 4 bolts connecting the front shaft to the transfer case, remove shaft and dyno away!
No need to pull fuses, no need to bleed stuff. It's a very simply 3 minute operation. You don't need to be a rocket scientist to do this.
This topic comes up every couple months now. Can a mod PLEASE sticky this thread before another pops up in the near future.
Cool,
So I check it out. Just undo the 4 bolts from the front of the driveshaft (connecting to the front diff) and it should just pull out from the socket where it conect the transfer case. Looks good.
But, I just wanted to check how long the can be driven like this. Is there any potential for damage aside from the possibility of dirt/rocks accumulating in the sockets, etc. So say a 20 minute drive to dyno after hoist would be fine & then 20 minutes back to put driveshaft in should be fine.
I'll post a pic of driveshaft later & also when i do it a few shots of it coming out.
I've pulled the fuse in my dash a couple of times to finish off my rears before I get new rubber and have noticed the air-con doesn't work. Fan works fine but just not cooling down?? I wouldn't have thought these are interconnected. Strange....
    • And if you want more power, more reliably, and cheaper, go get the Aussie RB... The 4L Barra and put that in instead.
    • No cats will keep discolouring the rear bar. Sends white paint a weird yellow stain. Cut and polish normally gets it out, but you'll be doing that every fortnight I found.
    • Both heads will be equally reliable or unreliable depending on what you do to them.  Stock the RB26 head will flow more. You have access to the stock intake ITB manifold on the RB26 cheaply which flows really well(1000hp+).   Arguably more aftermarket support for RB26, though in Aus we love our RB30 SOHC heads too.    The only downsides to the RB26 head is if you have a VL commodore and want to keep the SOHC look.  Where you may have an issue is drilling out the rb30 block for the bigger head studs but if you are building a big power motor you'd probably put bigger studs on the SOHC head too.  This is just about finding a good machine shop, sometimes easier said than done.  RB30 head worked can make big power just like a Rb26 head, so really it actually more comes down to what your preference is for your car.  People now even making billet versions of both.
    • 2630s work perfectly well. There is something to be said for just using the 30 head, as it saves all the pain of the conversion, still makes tons of power, still sounds cool, etc etc. 2630 will obviously make more power again, but the differences are not stupidly big. It really depends on whether you're racing for sheep stations or not. If it's dead serious, then it's a 26 head. If it's just for fun, it could go either way. But the 26 head and the effort to get it set up, etc etc, is part of the fun.
    • I've been building a 26/30 for a few years now. I've had the head built with all the good stuff. I had a 32 gtr but blew it up and yes its all going into a vl but im looking for some advice from some RB nuts on pros and cons on putting a 26 head on a 30 bottom end is it worth it Works are as follows Head -Extensive porting 1mm oversized supertech valves Supertech double springs Supertech valve guides Supertech titanium retainers Tomei solid lifters Tomei 270 x 10.25 cams Head drain Bottom end series 2 rb30 block Cp ceramic coated pistons Eagle rods Romac balancer Oil restrictions  O ringed blah blah spent a fortune And will get a girdle because the 30s arent used to handling that much rpm Nitto billet oil pump Hypertune plenum 6boost mani Refurbed astra pump thats the cover for it in the boot I did have a precision 6262 but sold it because drag car life. Currently building the ass end full 4 link floater rear end with a 2 speed  But the dilemma i have is my mate rekens I should just stick with the 30 head for reliability. Has any one had any issues with mounting the 26 head ie compression blowing gaskets etc. Just looking for some advice from people who have gone down this route. Here's some photos. Blew the oil pump in the gtr and decided to rip the motor out at the time and do a full build only to find it had been a repairable write off so went down this path.
