Anyone form Queensland be interested in buying my car?
I'm selling for $16,000
Car - 90 Model R32 GTST Type M
Mods - Full 3inch exhaust with wastegate bypass, 500hp Garrett GT Twin Ball Bearing Turbo, Large PWR front mount intercooler, Bosch 500hp fuel pump, Malpassi Reg, Ross forged pistons, Shot peaned connecting rods, balanced and blueprinted internals, Race main bearings and competition big ends, Air/Fuel guage and oil pressure guage on dash, 4 puck button clutch, Lightened flywheel, Sports steering wheel and Pod filter, Water Sprayed intercooler, ported head.
250rwkw running 12 PSI Boost.
Has done 5000 km's since rebuild. Tyres have almost 3/4 tread. New discs on front. All new heater hoses. New timing belt, New drive belts. New thermostat.
Paint job on front of bonnet leaves a little bit to be desired ie. stone chips.
https://www.sau.com.au/forums/topic/65378-this-car-is-going/
"This car sucks its blown another turbo"
"For sale: said car"
You are low. lol
The reason for the turbo blowing was oil contamination caused by the bearings failing caused by the bent cradle. All is fixed now....except turbo. Entire centre and shaft has to be replaced. I'm selling for $15,000 with the blown turbo. Still $16,000 if I fix it.
A lot of dollars spent on this engine.
Price will never go below $16,000. Buy a standard one if you want to spend any less.
I have spent $9,000 on mods alone - That's all trade price and no labour.
The car owes me $26,000 so $16,000 is a fair price I think.
I am looking to upgrade - or downgrade - to an R33 minty stocker. So I can be a Nanna driver and attract less attention.
A car with a fully rebuilt engine, decent turbo (which can be rebuilt), intercooler, etc, etc is a great price for circa $16k
Most are asking $15k for a stock R32 GTS-T these days :rofl:
Its not our fault if clowns pay that much :headspin:
Any pics 3LIT3 FORS3
Try http://www.imagehosting.us for posting pics..I just found it tonight, it's cool cos you don't even need to register
errr... so is this cool place called SKYLINES AUSTRALIA.. it has this AMAZING gallery function that nobody knows how to use, even though it's incredibly simple to use..
You click "Menu" up the top and "Gallery" and it's amazing!!
depends what else you combine it with, but in most situations I've heard it's safe :P:)
See at the bottom of my thing it says Photos: 81, you can view a whole heap of useless photos.. Filesize limits are large, etc.. and it even gives u the VBB link to use to include it inline in a post such as:
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
