Heres the measurements from my stock cooler which was removed last week from my R33 S1 GTST( gun metal grey :) )
225 x 185 x 59 - core size
350 - end tanks included
55 - inlet/outlet size
As GTST said "just under PISS SMALL"
:cheers:
  • 2 years later...
whats kind of boost can stock intercooler handle?
imo, i wouldnt increase boost through the stock smic. due to the small dimensions of smic it gets "heat-soaked" pretty quickly on stock boost. i mean you can up the boost, but be aware that your smic will get heat soaked even quicker.
invest in a bigger fmic and your away.
hope that helps!
cheers
hope that helps!
cheers
Some real world info for you.
the stock intercooler handles efficiently more boost than the factory turbo can safely put out. It flows reasonably and an R34 variant upto around 230rwkw. Do a search under Sydneykid and stock intercooler, to find his test data.
It won't get even remotely 'heat soaked' if driven on a street / track senario at those power levels (ie: over 200rwkw).
You can fit a better design of intercooler having said that, but like someone has already said get something thats the correct size for the job. My advice is to swap coolers once you have a turbo upgrade/ power plan worked out.
Hope that helps.
Edited by rev210
    • Um. No. Since Matt introduced the TIM it has become a lot easier to deal with the consequences of changing K for AFM and injector swaps. Then, tuning is a f**king doddle. No-one needs to know or care how many grams of air are flowing or any other bullshit. Need more fuel in a cell? Add more fuel. Need more timing in a cell. Add more timing. Need to adjust any of the other tables for warm up and so on? No harder than anything else. Sure - it's not an ECU system for starting from scratch on an arbitrary engine. But then.....it was never supposed to be, not recommended for, and almost never used that way. So.... On your engine, in particular, Nistune/Nissan OEM is about as sophisticated and difficult as banging 2 rocks together. Those ECUs are primitive and simple. There is nothing difficult there. I learnt Nistune from scratch, created new maps with extended axes, interpolated/extrapolated the original maps onto them and tuned my RB20 (basically the same ECU as your 26 ECU) all by myself, more than 20 years ago. And that was long before even TIM.
    • Set of knee pads for a R34. Will fit every model I think. Comes with everything except the rubber covers for the bolt holes. Still in great condition. You will need to drill holes to mount these or use double sided tape. I can do free shipping and will be shipping from the Netherlands with tracking.
    • Nistune needs something like an entire excel spreadsheet in which you build an abstraction layer that converts everything from real units you can actually measure into all of the various tables. The number of unexpected dependencies hiding in how the Nissan ECUs do math is a pretty impressive optimization trick for 8-bit MCUs but good god is it awful to actually work with in practice.
