Here are some pictures of everything you will need for the conversion
This photo also includes a factory computer and harness to suit a Neo motor and also the tail shaft, which the auto versions should be ok to use instead.
This conversion kit was removed from a 2001 H13 Stagea 27,000ks
Photo is from Yahoo auctions and had a buy it now price of 300000 yen approx $3500
Notice the clutch master cylinder, no vacumn booster
Clutch and brake pedal brackets are different from a R33, not sure about R34
Not sure if the clutch is a pull or push type, being 2001 model and possibly the same box from a R33 it could be pull type?
  • Replies 297
yes, i can 100% confirm that the S2 doesnt have a vac booster, but then you will need the S2 pedal set...which no one knows if they bolt into a S1?
HMMMM....someone has to find out! :huh:
I could still convert in future, no doubt about it, just want someone else to try it first, i am not in a financial position currently to find out
Oh, as a quick note...missing a transfer case ey? so it was a manual RWD
Ahh...
Here are some pictures of a R33 GTR vspec box
First photo you can not see the transfer box, second photo you can, if you look on the other side :huh:
And RWD gear boxes taper down more to the tail shaft and do not have the ribs in the alloy casing under the gear stick.
The conversion kit photo is from a RS Four type S, as ALL turbo manual Stagea are 4WD.
Touche my good friend, touche :huh:
One thing i dont quite get, why are autechs still so high in value. I mean, an R33 GTR costs around 30k these days, 260's are still around 35-40k
You can get a rough Autech 260RS for under 30K just like rough R33 GTR's
Good 97-98 R33 GTR's are still 35-45K if you import one
It depends on condition
I have seen 260RS go thru Japan auctions for approx $21-22k landed and complied, but were high K's and had previous damage
Also Autech's are very limited run, not mass produced like GTR's from the Nissan factory.
Have you seen the Autech 4 DOOR R33 GTR, only 100 made and sell for R34 GTR prices s/hand.
i paid 20000Yen for my R33 GTR gearbox, but the freight killed me bringing the total up to AU$1000. parts are insanely cheap in japland, but getting the heavy things here is still expensive
Did you end up buying it?
Or someone else beat you to it?
My highest bid was 62000
The final bid was 64000
Yeah at the price of $750 it would have been approx $2000 delivered to me in Brisbane plus would have to wait 3-4 months for it to get here
I have been waiting 3 months now for my R34 GTR front bar to come thru Slidewize imports
Should be here in 4 weeks apparently.
Terminal
There is 2xR33 GTR boxes for sale at the moment in the for sale forums for $1000-1100
On another note, full built automatic from Keas, new belts and clutchs, valve bodies, springs etc etc with a full manual controller is $3300 including a change over.
I will let everyone know how it goes when I can afford one in about 4-6 months (Just bought me a GCG for now)
EDIT: I admire how people on this forum help eachother out even when taking different paths. I think I will be the first/one of the first in Aus to build up a Stagea automatic....hope nothing goes too wrong (AKA, Auto shifting too fast for the ecu :O)
Terminal
Bugger, well when i looked for mine i couldn't find one anywhere. this one i got through slidewize is the same price anyway. no loss, just a 3 month wait
What i want to know is because it's a GTR box, do you have to use a GTR flywheel and clutch? or will a flywheel and clutch fit from a GTST?
What have you other guys used in your conversions?
There is 2 types of GTR box
89-93 32GTR are PUSH type clutch like all RB25det boxes and use the same flywheel
94 32GTR and all R33 GTR boxes use a PULL type clutch and am pretty sure use the same flywheel as RB25det. (I did a group buy on lightened flywheels with NPC approx 18 months ago and they were all the same)
So you have to get the right clutch to suit your box, either push or pull type.
    • Throwing my spoon to the soup here a bit.  When I installed a 044 back in 2012, along with the direct power mod, the car became very difficult to start. To a point I burned one starter motor as I was late for work and tried to get the thing going. With some tuning and careful use of gas pedal when cranking it became bearable. Trying to make this short as possible, but the 044 died after 2-3 years, after which I went with an AEM 320lph pump, which also died after about 4 years to my dismay. After that I went with a Nismo pump, and while trying diagnose an emissions problem, I noticed for the first time that my fuel pressure was 5bar/72psi on idle, and that removing the vacuum line did nothing. After monitoring the situation, and removing the direct power feed and going back to FPCM in attempts to remedy it, I noticed there was fuel in the pressure regulator vac line. Kept the FPCM, installed AEM external regu and the car became sooo much better in every way, including starting. And I had driven it like it was for 11 years.. Anyway, I agree these are likely two different problems, and the FP problem you just haven't noticed before. I do not know much about haltecs, but what first came to mind was the CAS, which probably is not there any more. So how is the wiring from haltec to gauge cluster? How is the battery voltage and alternator?
    • Your car was auto before? You have different diff ratio (auto vs manual i think? or n/a and turbo?)
    • +1 for getting a screen off alibaba, CarPlay/Android Auto is vastly better than whatever navigation cars had 10 years ago. I got an Android screen for my 2015 BMW, huge difference. Fully compatible with factory stuff including iDrive controls.
    • Yeah, my offer was more to show exactly how rough and ready the rig can be and still be useful. Youtube vids will definitely show cleaner setups. Same concept though.
    • I would guess the seal has gone down at the speedo drive and gearbox oil has crept up the drive cable sheath and fouled the speedo head.
