Here are some pictures of everything you will need for the conversion
This photo also includes a factory computer and harness to suit a Neo motor and also the tail shaft, which the auto versions should be ok to use instead.
This conversion kit was removed from a 2001 H13 Stagea 27,000ks
Photo is from Yahoo auctions and had a buy it now price of 300000 yen approx $3500
Notice the clutch master cylinder, no vacumn booster
Clutch and brake pedal brackets are different from a R33, not sure about R34
Not sure if the clutch is a pull or push type, being 2001 model and possibly the same box from a R33 it could be pull type?
  • Replies 297
yes, i can 100% confirm that the S2 doesnt have a vac booster, but then you will need the S2 pedal set...which no one knows if they bolt into a S1?
HMMMM....someone has to find out! :huh:
I could still convert in future, no doubt about it, just want someone else to try it first, i am not in a financial position currently to find out
Oh, as a quick note...missing a transfer case ey? so it was a manual RWD
Ahh...
Here are some pictures of a R33 GTR vspec box
First photo you can not see the transfer box, second photo you can, if you look on the other side :huh:
And RWD gear boxes taper down more to the tail shaft and do not have the ribs in the alloy casing under the gear stick.
The conversion kit photo is from a RS Four type S, as ALL turbo manual Stagea are 4WD.
Touche my good friend, touche :huh:
One thing i dont quite get, why are autechs still so high in value. I mean, an R33 GTR costs around 30k these days, 260's are still around 35-40k
You can get a rough Autech 260RS for under 30K just like rough R33 GTR's
Good 97-98 R33 GTR's are still 35-45K if you import one
It depends on condition
I have seen 260RS go thru Japan auctions for approx $21-22k landed and complied, but were high K's and had previous damage
Also Autech's are very limited run, not mass produced like GTR's from the Nissan factory.
Have you seen the Autech 4 DOOR R33 GTR, only 100 made and sell for R34 GTR prices s/hand.
i paid 20000Yen for my R33 GTR gearbox, but the freight killed me bringing the total up to AU$1000. parts are insanely cheap in japland, but getting the heavy things here is still expensive
Did you end up buying it?
Or someone else beat you to it?
My highest bid was 62000
The final bid was 64000
Yeah at the price of $750 it would have been approx $2000 delivered to me in Brisbane plus would have to wait 3-4 months for it to get here
I have been waiting 3 months now for my R34 GTR front bar to come thru Slidewize imports
Should be here in 4 weeks apparently.
Terminal
There is 2xR33 GTR boxes for sale at the moment in the for sale forums for $1000-1100
On another note, full built automatic from Keas, new belts and clutchs, valve bodies, springs etc etc with a full manual controller is $3300 including a change over.
I will let everyone know how it goes when I can afford one in about 4-6 months (Just bought me a GCG for now)
EDIT: I admire how people on this forum help eachother out even when taking different paths. I think I will be the first/one of the first in Aus to build up a Stagea automatic....hope nothing goes too wrong (AKA, Auto shifting too fast for the ecu :O)
Terminal
Bugger, well when i looked for mine i couldn't find one anywhere. this one i got through slidewize is the same price anyway. no loss, just a 3 month wait
What i want to know is because it's a GTR box, do you have to use a GTR flywheel and clutch? or will a flywheel and clutch fit from a GTST?
What have you other guys used in your conversions?
There is 2 types of GTR box
89-93 32GTR are PUSH type clutch like all RB25det boxes and use the same flywheel
94 32GTR and all R33 GTR boxes use a PULL type clutch and am pretty sure use the same flywheel as RB25det. (I did a group buy on lightened flywheels with NPC approx 18 months ago and they were all the same)
So you have to get the right clutch to suit your box, either push or pull type.
    • 2 does "sort of" applies, maybe......but looking at what parts would be needed for the swap to get engineered, registered, and insured, and basically that's everything under the car, the modifications the make it legal would be problematic and horrendously expensive, all for a street car that just cruises around and hits a few twisty roads on the weekends Also, from looking at the NSW rules and Regs, with all modifications that is required just to make the car safe and not twist itself to pieces, and then actually get registered for street use, may still be impossible nowadays As for 1, when you add in a fresh engine, fresh transmission, rear cradle and diff, tailshaft, suspension, brakes, cooling, and all the other fabrication required, your probably looking at up to $100k to do it right, all for a 20 year old MX5 that is over engineered and you would never be able to actually use the power it has on the street, much like your beastie, which I love, but you actually track that thing and can use all of its powers in anger, in a safe environment  Hell, the old Bogan Cruise Ship had more power than I could use on the street, and in hindsight, I went a bit silly on that thing, it didn't really need the 500hp it had for what I actually used the car for, it was fun, but basically unusable on the street if you value your licence  As for cams, yeah, I'll probably book it in for them to get installed and tuned soonish, like next month after MX5 Mania are back at work....... and yes, I've already sent a email to bin the turbo quote and quote instead to install cams and a new Fluidampr balancer that will suit the 2.5 better than the OEM 2.0 balancer that is swapped over for the 2.5 install, as the balancer needs to get pulled to time the cams it's a while your in there sort of thing I did think a bit about flex fuel for a laugh, but being na, and no where really around locally anymore to get E85, I've binned that idea, so no sweet sweet corn smells are set for the car I wish E85 was more of a standard fuel, it's better for the environment, better for tuning, plus that sweet sweet smell we all love As for fitting in the family, that's not needed, as everyone in the family already owns a car that can seat 5 humans comfortably enough, the MX5 is "my toy" As for buying a car that is already built, nah, I would rather pick and choose my parts, I enjoy the process, and in the big picture, the additional cost is well worth the enjoyment, and the occasional frustration, I get out of doing it, albeit with other people spinning the spanners, and me, just paying the invoice 🤣
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
