So an R33 RB25DE 4WD pedal box won't bolt up then? They are a push-type box but I'm thinking it may be the way to go so I don't have to modify the firewall
The other thing I am wondering about is the Brake Booster. They are much bigger on the Stagea compared to the R33 Skyline unit. Does this need to be changed or is there enough room..................actually I might change it anyway, firm up the pedal a bit
Oh & has anyone got pics of the recess job on the firewall?
Edited by tRUkbOY
  • Replies 297
http://www.skylinesaustralia.com/forums/in...7502&hl=booster
heres a thread i made ages ago on it, but i changed my username since i got banned :/
thats got some pics of my booster mounted (for the rb26 engine though) but i'd say the 25 would have more room than the 26 because of the 26's plenum which is mighty close. brake booster is very very very close but just enough room in the end :)
shows some of the pedal mountings further down the page as well.
good luck, and i think page 3 or 4 on this thread shows some pics from user "Argo"
hope it helps
Brad
Edited by CruiseLiner
pics dont seem to work for me.
also i dont see why u cant just use the non-booster one from a series 2 stagea and get the pedal box etc to match the master cylinder length (also the series 2 stagea)
dunno the difference in pedal feel but recessing the booster is a major job and as i've said i wouldnt attempt it with the motor in the car as its sooo tight around the area.
"also i dont see why u cant just use the non-booster one from a series 2 stagea and get the pedal box etc to match the master cylinder length (also the series 2 stagea)"
Thats the only other option Id go for. If the S2 pedals bolt into an S1
i seriously doubt the s2 pedal box will "bolt" in simply, the footbrake thing has some weird mounting spots and doesnt match the pedal box at all (going by my pedal box which is the gtr one i think). very simple job to bolt it in but, just weld one tab off one side of the box and make one of the original holes in the box abit bigger and it fits in almost perfectly using the factory bolts from the original footbrake setup.
the pics in that link i said shows u how i mounted the box but they are alittle crammed under the dash to get any decent distant shots.
Ok is it just me or does this look like its not recessed?
http://stagea.st.funpic.org/082105/stagea29.JPG
http://stagea.st.funpic.org/082105/stagea28.JPG
(hope you don't mind this Ska)
Meh they are on teh intarweb for all to see, I am just sorry I couldnt give you the answer to that question :P
Oh and I forgot if I had mentioned this but I do have genuine GTR pedals :)
Not sure if it has been covered before in this thread
Does the gearbox transfer case ratio matter if using a GTR gearbox for the conversion or should a GTS4 box be used?
Does the diff ratio need to be changed?
And also, has it been confirmed what clutch master cylinder a series 2 factory Type S uses
Vacumm or not?
i dont get the questions properly darren, the diff ratios have nothing to do with the manual conversion, and the transfer case doesnt have its own ratio or anything, the gears in the box do though, but the 4.3 diff gears in the stock stageas should be alot better than the gtr 4.11 gears for getting moving and pulling the extra weight.
use a gtr 5 speed and tf case as they are nice and cheap these days at under $1k :O
hope it makes sense :)
The question did not really make sense to me either once I wrote it
I was told by someone the other day there maybe issues with using the GTR gearbox
Anyway, I can a GTR R32 box for $500 and GTR R33 for $800 or a R32 GTS4 box
Might aswell get the R32 GTR box then
Thanks for the clear up
    • Sounds like the rack seals blew.
    • ^ This is all good advice. I can imagine that there's some passive components in the HVAC controller that run that PWM output that could die, or suffer bad solder joints. It can be worth opening it up, taking a schmooze around looking for swollen electro caps, evidence of liquid escape anywhere, tracks that have been hot, lifted, cracked, etc. A DMM might not be suitable for seeing if the PWM output is pulsing. Might be too fast and too low voltage for a DMM to keep up. An analogue voltmeter might give a better hope. I use a handheld oscilloscope (<$100 from Aliexpress if you want something cheap). A DMM might see the voltage across the motor flicker. Otherwise, as above. If you can successfully see PWM action, then the control side should be good. If you can't see it with what you have, you might need to step up the instrumentation used, as above. Beyond that, and dbm7's advice on testing the motor directly, you're down to looking for broken wires, corroded connector pins, etc.
    • So Thanks for the comments etc. To follow up on this, we went down the path of fitting a divider down the middle of the external pipe that was added to the exhaust manifold and the divider went from very close to the external wastegate all the way up to the "V" part where the pipes from each side of the manifold joined. After this modification it was finally in a position to do the dyno-tune with some degree of success. Top end power was down about 10kw (250rwkw down to 240rwkw) I believe from previous but it seems to be more responsive lower down and at least it is now driveable and fun and back on the road to be enjoyed. Apparently the timing couldn't be run the same as it was running into knock and boost was down about 1psi. For all we know this could have been from the fuel being a bit older, or perhaps some slight complication from the new head gasket as we didn't have compression figures from before that mod to compare. I'm no mechanic and this is second hand info but I just wanted to follow-up to those that commented or read the original post with interest. After so many months of stuffing around this is a big win. The interesting part was most of the info around this was gained from information around Barra motors and not GTR as the manifold setup on the Barra with single turbo was more similar.  Thanks for those that helped with info. Regards Rob
    • G'day ... first up, I very much doubt that's a resistor network (as used also for this job), but the part# looks right. The description of 'power module assembly' looks to be nissanese for 'PWM driven, ground switched, DC motor speed controller'.... the circuit in the schematic kinda infers that's the case... ...with the transistor symbol appearing in the unit described here as 'Fan Control Amp(lifier)'....being driven by pin20 on the HVAC unit,  and a feedback signal on pin19 from the motor negative terminal for some reason (might be motor fault detection, maybe they detect commutator switching to determine motor revs as well, I dunno)... but if they are  counting commutator spikes, a bad segment (or really worn brushes) will throw a spanner in the works... The motor itself will as said be brushed DC with segmented commutator, rated at 12VDC nominally ~ now-a-days I just unplug them, determine the positive wire, and hook them up to a variable power supply and find out how much current they draw, if they work etc etc ...you can also check for bad segments...ie; set the power supply up to feed 1volt @ 2amp max, then watch the wattage count as you slowly rotate the fan blower motor through a complete revolution ; any bad/dead segments will be clearly evident...some folks would just say determine the positive wire, and feed it battery voltage, and if fan spin, you've got a win...<grin>... well, at least that infers it should do something when plugged back in, and the HVAC unit commands it to run... and if it doesn't, you suspect the module, but you should check the PWM signal on pin20 is actually present, and if it is, blame the module ...
    • Ah. OK. I take it back. I hadn't looked closely at the R33/4 arms and presumed that GKTech did as GKTech do everywhere else, which is to use sphericals there. The poly bushings are made to be 100% interchangeable, should use the standard bolt just fine. Every other bush in every other place in pretty much every other car, does.
