  • Replies 297
96911-0V800 Body-Console
96920-0V800 Lid-Console Box
68430-0V800 Holder Assy-Cup
96935-0V800 Boot-Console
96965-AA001 Holder Assy-Cup
I don't know how much money it would save anyone looking at following beastien's lead but the last part number - the Holder Assy-Cup - uses an R34 Skyline part number. Which means you may be able to purchase it second hand locally of an R34. Just a thought
Part number for Series 2 Stagea type S clutch pedal 46550-0V700 (thanks Alex)
This suits the standard type R34 master cylinder, not vacumm GTR type
Well, I got the part yesterday and it is not the clutch pedal, but it was the bracket that the pedal and master cylinder bolts to
It should be just a case of removing the foot brake bracket and bolting this new one in
Will go to Nissan and try to get the clutch pedal now.
Just got back from Nissan and orderED some parts
compltete Stagea clutch pedal with bolts, washers, rubber foot pad
Part number 46540-0V700
$86
Stagea and R34 clucth master cylinder
part number 30610-AA107 (use to be number 30610-AA120)
$118
Stagea clutch pedal and clutch master cylinder mounting bracket
Part number 46550-0V700
approx $115
Also confirmed by part numbers the R33 manual brake pedal is the same as the Stagea
So will get one s/hand locally
$86
$118
approx $115
What's the difference between the 1st part and the 3rd part? is the mounting bracket separate from the pedal?
The clutch mounting bracket is similar to photo attached
The photo is of a R33 bracket, which is diifferent to the Stagea
That would be great :)
I'm still trying to figure out why the hell it costs so much to convert a Stagea to manual though... One of my mates converted his R32 4 door to a manual last weekend. Cost him $700 all up
Gtr gear box $500-1500 s/hand
Clutch pedal, bracket and master cylinder $320 new
braided clutch line $100
Clutch kit R32 push $450-500, R33 Pull $900 new
Centre console new $1000
R33 hand brake s/hand $50
R33 brake pedal s/hand $30-50 New $90
Flywheel s/hand $50-100
Misc -oil etc $150
I think that's it
Centre console is the killer
Ok so why exactly do we need the centre consol? My mate with the R32 just covered the original space from the auto stick with a gear boot. Looks great! Is that something which we cant do in Stagea's?
to fit the handbrake, you need to cut a massive hole in the console, and also for the gearstick you need to cut away at the lid over the shifter. you can use the original, but it won't look very pretty without a bit of restorative work.
also when you get the manual console you get 2 more cupholders, can't have enough cupholders
Thats a very good point. 2 Cupholders isnt enough... well I want to do this conversion once the online store is up and running. I'll see if I can get away with it for under 3 Grand. One more thing - is it necessary to use an after market ECU aswell?
    • I should note too as I have all 4 wheel speed inputs to the emtron I now have the emtron controlling the attessa solenoid for 4wd/traction and launch control strategies.
    • It works quite well with the adjustibility within each of the programs of the turbolamik. Essentially p1 is drive and lockup comes on like a normal driver.  But in program 7 I have customised it to not request the lockup clutch to engage until something like 6500/7 when slip was the lowest.
    • Yep, I like that. The tags are only on the first post of a thread and we don't get huge numbers of new threads. Also, I plan to add some more report types and we could have a member report type like 'review tags' then members could flag if they thought a topic wasn't tagged correctly.  No way man, I dig the input. Thanks!
    • It's a valid thought. There's not exactly that functionality already (when creating a thread) - that's where the OP can use/create any tag they want. We'd have to come up with a way for the user to request their tags get reviewed or something. Otherwise the mods would have to review every new post's tags (for those that have them, anyway). There's kind of that functionality already exists to some extent, post facto of starting the thread, where the OP or any other user could report the post to admins, and request that tags get reviewed. We could do this already, and any user could already have made such a request. To make it a part of the forum proper, it would require an initial and an ongoing education programme, so that people know that it's a thing. OP based tagging/request for review would also require at least some (probably most) of the user base to be told that it's a thing they can do. Both of these things probably wouldn't spread too far and/or get used very much. If it was the standard approach on a lot of different sites, then it might do, because people would be used to it. Prank's approach to this differs from my original thought, by leaning into tagging. Which is fine - it's possibly better than what I originally suggested. In fact, I just went to the R32 GTR wiring diagram thread and added tags, including "Library". That's probably a good way to use tags and the idea of a library. We just have to drag together an (organised!) index of threads or posts that have that tag. I have yet to do any of my own follow up by pursuing worthy threads and posts and reporting/marking/tagging them for the library, such as the @Sydneykid stuff I was talking about, and possibly any amount of @Lithium 's and others' posts. At least if I tag them Library, we'll have a start.   Back to @Wazmond's idea as it relates to @PranK's, we might have some sort of a list of tags that are already used to scrape for this library. I'm not entirely sure how that would be presented or used, particularly if it got long. But it's yet another idea!   cheers
    • Just a thought, but instead of restricting, is it possible to do like an "up for review" kind of thing? Where say someone who's not an admin/mod tags, it would require approval for it to actually tag? User posts with a 'tag' > Admin/Mod Reviews > Approves tag > Tag now exists kinda thing? Just came across this thread so Im not too sure if Im straying off topic or not but forgive me if i am...
