  • Replies 297
one point to remember, the auto rb25 engines have a little bush (collar) thing in the back of the crank. which the auto shaft slides onto. well this collar needs to be removed from the crank before the manual can go on >_<
good luck
Brad
Oh yeah. True. I am going to test fit the pedals before I get to carried away too
Do I need to pull my dash to drill the hole for the Clutch Master Cylinder?
Nope, but you do need to remove the RB25 intake plenum.
The easier way around this all is to just remove the entire engine, swap the gearbox with the engine off the car and do all the required drilling and fitting for the clutch master/lines and then put the engine/gearbox back in one go...
Let us know >_<
Well I wasn't going to do it that way but realising that I'm going to have access to a hoist & gearbox jack and I have to drill the hole for the clutch master cylinder, its probably the best way to go. It'd probably take me an hour & a half to undo the gearbox bolts in which time I could probably drop the whole front subframe out anyway. Cheers
R34 Clutch Pedal
R34 Brake Pedal
R33 Clutch Master Cylinder & Lines
R34 Centre Console Assembly (to be fused with Stagea Console)
The type S Stagea uses a
Stagea clutch pedal, approx $80 Aust. thru Nissan, they are diiferent to R33 & R34
R34 clutch master cylinder, not sure about lines
R33 Brake pedal
I have bought these 3 items for mine
I measured up a R34 console and thought it may be possible to use, but it will take a fair bit of playing around to get it right around the gear stick surround
I think I would prefer to remove the dash before the engine, it would quicker and easier to do, aslong as you can the master cylinder in. It is pretty tight behind the inlet plenum.
i recon the engine is easier to remove than the dash, and ive done both plenty of times.
dash has about 50 screws/bolts and when i did it i didnt know where they were which took me ages to work out, but with the stagea service manual should help
fun times ahead :)
compltete Stagea clutch pedal with bolts, washers, rubber foot pad
Part number 46540-0V700
$86
Stagea clutch pedal and clutch master cylinder mounting bracket
Part number 46550-0V700
approx $115
Have your parts arrived yet? I'm pretty keen to see photos of them
Edited by tRUkbOY
I have the parts, but the my camera is still getting repaired (been 4-5 weeks)
The pedal came with the rubber foot pad, but no bolts
Damn.
I know its not a precise measurement or comparison but my R34 pedal looks identical to that in the picture. We shall see I suppose
Try not to fall off your chair will laughter but if anyone has a Manual Centre Console they'd be willing to part with, let me know................
I just got up off the floor..
A new one for $750au plus freight to NZ would be best deal
I got a s/hand one out of JP and cost me nearly that much
Have you seen this thread?
http://www.skylinesaustralia.com/forums/in...howtopic=122494
Hey guys.
$150 there abouts to modify your auto one with a manual gear souround , move the coin holder and a slot for the handbreak :D
in a few weeks ill get them todo mine and we will see how it go's but for a example of work . this is a picture of my friends dinn slot they put in for his liberty :laugh:
premodding
after
they didnt re mould the rest because they had trubble matching the plastics. but that isnt a concern for us anyway, :laugh:
`josh
I would like to add a link to this thread in the "Stagea Diy's, How To's, & Fyi's" thread here:
http://www.skylinesaustralia.com/forums/in...howtopic=102808
And then unsticky this thread, any objections?
I am doing the manual converison this weekend (yes I will try to get as many photos as possible) but I just want to make 100% sure that I can use the Stagea auto driveshafts (front & rear) and crossmember. I have measured the auto box vs the manual box & the crossmember lines up at the same point but can someone please confirm this for me?
Edited by tRUkbOY
hey mate yes the stagea front propshaft and rear tailshaft fit no problems. both boxes are indentical in lengths :(
im 99.999999% sure the stagea auto x-member fits up too as they are the same as the manual ones (i did mine 18 months ago so my memory is not the best), so just have a look if the gearbox rubber mount is the same as the manual one and if it is then it will fit for sure.
hope it helps and good luck
Brad
Edited by CruiseLiner
I agree there are way too many stickies at the top of the page put it all in the one spot and we will know where it is
    • You're not wrong, but more than a few times I've heard of people running into issues where their injector characterization isn't quite right and that approach works for that specific configuration but once they switch over to a new set they discover a whole bunch of stuff wasn't set up correctly. It's slightly more annoying to reverse engineer the OEM MAF transfer function but you already have the sensor wired up to the factory harness so keeping it around for a few weeks more while you figure out the tune is easy enough. I've seen GM also use a combination of both MAF + MAP in their ECUs before, MAF is for steady state and a calculation of the cylinder VE to correct the base VE table, then in transients it uses that calculated VE + raw MAP to determine cylinder filling somehow.
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
