  • Replies 297
Now that we've figured the push/pull, what clutch do you use with an R33 GTR box and an RB25DET? do we use a GTR clutch or a GTST clutch, or do they both fit?
Also on a happier note, my gearbox will be here in 4 weeks!!! time to get stuff organised!
If you have a R33 GTR gearbox then you will need to use a PULL type GTR clutch, as RB25det clutches are push type in R33 GTST, not sure about R34 GTT
It does not matter what engine you have, series 1 R33 or Series 2 Neo or Rb26, it does matter what GTR box you have. (hope that makes sense)
  • 3 weeks later...
Well i got my Master and Slave cylinder fresh from Nissan today, getting one step closer now. my gearbox is due to arrive in melbourne end of next week.
Did you end getting the GTR vac type or 34GTT type master cylinder
I got the R33 type master, as i'll be using an R33 clutch pedal with a little modification to fit. i spoke with my mechanic, he said there's no trouble matching the R33 GTR slave to the R33 GTST master, and he think he can mod the clutch pedal to fit.
all i'm waiting on now is my gearbox arriving then it's all stations go. i'll let everyone know how it goes, any problems i get and so on.
  • 4 weeks later...
Has anyone got any pictures of how they secured thier handbrake foot to the floorpan? Mine did have 6-7 welds, but the metal is really thin and the some of the welds didnt go through both pieces of metal, so now it has become dislodged. I have one screw just holding it there, but would like to know if I have to get it re-welded or will 10-15 tekscrews be fine/safe to hold it there? Also will they hit anything underneath the floorpan there, like gearbox.....?
Out on the turps mucking around with a mate, nothing serious though.
the console looks good, will be better once it's in my car though. thanks heaps. just waiting on the all important gearbox now before i start getting ready for not having a car for a few weeks
Shit happens ay :w00t: i can't wait to get things rolling aswell, just a couple of things to go, clutch and a few bits and pieces. Yeah then the problem of finding time, and most likely having to do without the car.
Has your gearbox arrived yet from Slidewize?
I received a email about my GTR front bar has arrived and have paided for the shipping to Brisbane
Should get it by the end of this week.
I have found a late R32 gtr box (push type) for $750 thru a importer in Brisbane, just deciding whether to get it now or later for the conversion.
nope, no gearbox yet. i need to get it here so i can find out what type it is, as i've been told there's a push and pull type gtr gearbox for R33...
no rush anywho, i need this cast off before i can use it
    • Hey, yeah I really like the color. Only paint I'd rather have is KN6, but those are expensive. Right now I'm trying to get the car to the point where I can get it tuned to 370hp so the whole setup can be driven legally, and pass the next inspection that is already due anyway. Beyond that lots of rust fixing I'm afraid, winter project is most likely going to be a front end teardown and fixing the strut tower rust. I know these can be driven daily but I don't think I will do so anytime soon. Will post a build thread soon with a list of issues and futute plans.   Cheers
    • Wanted to reply to this topic. I'm in the somewhat same boat with our Stagea. I'm trying to install a different rear diff. The Stagea/Skyline uses mounts on top of the rear diff for the ATTESA pump. Any way you can relocate the pump? I did find this kit https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • So here's the deal, my wife picked up an S2 AWD Stagea. Super cool, clean car. Looks like the owner in Japan went track spec as it's got some heavy modifications including Exedy twin disk, tension rods, coilovers, GTR brakes, oil cooler & a Nismo 2 way rear diff. Now, cool mods for sure. But, she is just using this as a casual daily driver. The 2 way rear is AGGRESSIVE. It also has solid subframe bushings & poly diff bushings. So that doesn't help either. So far I've tried changing the diff fluid to the correct fluid. Even tried a little friction modifier. No help. This thing clunks, skips the tires & has some slight whine/NVH when driving. Might sound like I'm being picky, but just trying to find a better solution. Here in the states, it's impossible to find a Stagea rear diff. No luck. I do have a 300zx non-turbo diff. Same ratio, 5 bolt axles. On the Stagea, you need both front & rear diff ratios to match. This car is a 4.083. I'd like to just swap a normal rear diff into this thing. Nothing fancy. Even open diff is fine. She's not tracking the car LOL The difference is that the ATTESA pump mounts to the top of the rear diff. There are 3 total mounting points for the pump on top of the diff. With all this being said, what would be the best way to go about this? I could remove the Stagea diff & see if I could get somebody to possibly weld the 3 tabs/mounting points onto the 300zx diff so we could mount the pump on the 300zx diff. I could swap the internals from the 300zx into the Stagea diff but this is not in my comfort zone. Is it possible to mount the ATTESA pump to the underside of the car? Sorry for the paragraph. Just trying to figure out how to go about this. Any help is much appreciated! Stagea Differential - Note two top tabs, one bolt hole for ATTESA pump mounting   300zx Diff - No mounting tabs Also found this mounting kit ?? https://theskylineshed.com/products/nissan-oem-attesa-mounting-kit-to-suit-r32-r33-r34
    • Not ready yet, but maybe later in the year?
