  • Replies 297
G'day Christian,
Cool to see another person doing the manual conversion. Be sure to write down all the parts (and rough $$) :(
Yeah, I think they were push up until late 93 and 94, then they went to pull. BUt itn't it the R33 GTR box that you need? Or are the R32 and R33 GTR boxes the same ?
Anyone else confirm.
J
  • 3 weeks later...
gary you mentioned that it was bit tricky to get the power fc set up. can you explain what you had to do to get it set up. did you wire it into the auto ecu? or did you use a manual ecu from a gtst or a gts-4. also did you need to cut into the firewall to fit the clutch master or did it fit ok with the rb25. did you cut up your console or source a 260rs or series 2 console from somewhere?
a few pics would be cool too if you get a chance.
everything that went into my car was genuine rs 260. Modification of the firewall was still needed as this is different between the auto's and the manual. I dont know exactly why nissan do it but they do. All the centre console was genuine rs 260 and was fairly easy to get out of japan, it took about 10 days.
I have now sold the car to another forum member and he picks the car up on tuesday i think so you will be able to get all the pickies you want as i am sure he will post a hell of a lot, he loves the car and i am glad to see it go to a good home.
Cheers
Gary
good info gary thanks cant wait to see the pics from the new owner
also another question about the ecu does anyone know if you would be better off using an r34gtt or awd rb25 ecu as the sensors for the stagea are the same or is it just a matter of the things like climate control and dash electrics and so forth being different?
  • 3 weeks later...
OK I'm the new owner of Gary's beast, I dont mind taking pics, I'll borrow digital camera for the weekend and go crazy, so what pics do you want?
And I am by no means a mechanic so just tell me where you want the camera pointed at in small words a four year old could understand and I'll do my best :(
Oh and going from a fairly modded r33 (~180rwkw) to this beast (??awkw) was the best decision i ever made, the stagea has a lot more grunt running on about the same boost, and handles a lot better, mainly due to the stagea having proper suspension setup, shocks and springs and the old r33 had stock suspension.
Yeah ummmm I am not too keen to start ripping off the surronds, mainly because I only see the car on the weekends atm, and dont want to ripp it all off and not be able to get it back on, yes it is possible for me to be that unco :unsure:
No way it is going up on a hoist as I do not know anyone close by that would put it up for me.
I do understand that pics of the surround are goign to be useless though so we'll see what I can do, I'll try to get some pics of underneath the car, but dont know what I am really looking for though, so I'll just go crazy and take as many as I can ;)
    • Strange your posting about this being an issue. Move the harness or change your wheels or run more camber etc. Have the thing not touch the thing so it doesn't destroy the thing.  Short answer, no. Slightly longer answer, the factory fuel gauge is measuring resistance. You need to wire in the FPG fuel level sender into the original factory fuel level sender wiring.  I drew you a picture to explain this one The factory strainer is quite long, reaching down into the bottom of the tank. Safe bet your aftermarket fuel pump has a little baby sized strainer that probably doesn't even point down towards the bottom of the thank.  Solution, move the pump lower down in the tank, or fit a longer strainer, or do both. I did both, I've run my tank down to 5L remaining and the car still drove fine.
    • S2/3 GT-R is the same as S2 GTS-t The SRS airbags module in under the centre console. The S1/S1.5 GTS-t and S1 GT-R had the module built into the steering wheel. FWIW, I have a S3 GT-R wheel in my S2 GTS-t shit box. Same airbag plug, airbag light goes on then off, meaning all systems are go. S3 GT-R has red stitching, that's about it.
    • Dumb question, but why would it matter if the wheel came off a car with hicas or not?
    • Hey to anyone that reads this, long time lurker first time posting, sorry if it’s been answered before but I’ve been looking for nearly a year now for answers. ive got a 25det neo in an r32 that works awesome when it works (made 500whp on 21psi) but works 45% of the time, 1st issue there’s a harness that runs under the passengers side front fender that my tire keeps rubbing through and one wire seems to power the fuel pump even though I’ve done the relay “mod” some people like to call it, and when it does rub through it kills the car, yes next time I’m with the car I want to take the fender off and try tuck the harness well out of the way but I’d also like to try and by pass this mysterious wire as well lol, also wouldn’t mind getting power from the alternator as I’ve read it supplies the pump with 13v ? But no idea where to run the power wire too. 2nd issue, when replacing my fuel pump and fuel hanger I managed to break the factory fuel level sender leaving me with no fuel gauge, I’d like to buy the fpg fuel level sender for r32/s13 but the plug it comes with confuses me, I’ve got a detschwerks x1 fuel hanger which has light + pump - level + pump + and a ground, I’m no auto sparky but I’m wondering if I can cut the plug off the fuel level sender and wire the negative to the pump negative and wire the positive to the level positive to get a fuel gauge back ?🥴 3rd and final issue, the reason I want a fuel gauge is because whenever it’s below half a tank, it fuel starves like crazy and runs like a bag of shit even without doing a pull or sloshing the fuel round in the tank, I’d also like to fix this but have no idea what’s causing it, I’ve got a dw420 and a dead head fuel setup meaning the fuel is regulated before it gets to the engine, my only theory is that the return line is to close to the pickup on the pump and when it’s at half a tank the return line is causing the pump to cavitate enough to cause fuel pressure issues, that or the pump isn’t low enough in the tank which I would find strange considering I can’t find a single thing online about it, also if ya wondering how I figured out it happens at half a tank without a fuel gauge, I waited until it started happening and went and filled up and the car took exactly 30 litres every time I tested it, if ya managed to read through this mess I appreciate that and any recommendations , cheers
    • ChatGPT is trash and lies about things I would not expect it to lie about considering many things it's wrong about are very easily verified with google. The S3 R33 GTR shares its steering wheel with R33 GTSTs of the same production year. Part number is 48430-26U17. I'm guessing you have to get it from a car that came with HICAS though, the ER33 is 48430-26U18, but the HR33 diagrams note that part number is still leather vs 48430-26U13 which is not leather-wrapped. They all use the same airbags, so if you need another one you can get it off basically any same year R33 or Stagea.
