if you haven't done this yet.
remove the two screws above the A/c controls. remove the ashtay. pull centre trim out. disconnect the rear demister and the hazard switches.
remove the existing radio and put the panel back on.
use the radio cage and crimp it into place. the plugs are early nissan items so a nissan plug kit should help.
match up the wires connect the antenna and slide the radio in
on a n15 you can do it. the local ones here have thin crap brackets that have to be redrilled to work. it slides in and there is no need to do any cutting. the radio sits where the ac controls are on the jap n15 cj2 that you are thinking of. they also use a eurovox radio.( not sure what NZ new use)
which is better than what oz gets. it has brackets and you can use them. the local one is done easier the other way.
n13,n16 are a different matter.
ALL aftermarket single din stereos I have installed screw directly into the factory stereo brackets of ALL Nissans, except for the early 90's Terrano which requires a fitting kit. Pulsar, Skyline, Primera, Bluebird, etc etc are pretty much all the same to install stereos in. Toyotas are also more or less the same. Some require fitting kits aswell (ie: The Toyota Windom).
Im still not understanding why a cage should be used.....
  • 9 years later...
Thanks.
Your basic guide is very helpful - taking of the center trim was easy enough to remove and so is the headunit... however the adaptors I bought (ISO to Nissan) are completely different.
Seems the car doesn't use the standard "Nissan" plugs - the "look like" the ones for a Holden.
My wife's car is an Aus spec N15 series 2 with the factory CD player (Eurovox 8580N) - I'm going to assume the radio wiring was probably updated to accomodate the CD player as the N15 series 1 had a tape deck.
Can someone advise which is the best adaptor to get. I'd like to avoid hacking up the factory wiring.
I figured it out, the N15 S2 Pulsar uses an older style connector.
If you happen to be purchasing the Aerpro branded adaptors, make sure it is for "Nissan 1987+" not the "Nissan 1995+"
Pic attached.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
