We finally found a quality r32 gtst!
It's a black December 89 type M. We wanted a 93, but would not say no to an 89 in good condition, which this was.
It is stock, which is exactly what we wanted... even has stock exhaust! Only mods are a radio and a TV inside which needs to be played with to get working in Aus.
Our engineer looked at it today, and gave the all clear after many tests. This engineer has worked on and raced GTR's. He saved us a lot of money.
So many trips out to Preston... can now stop spending so much time on carpoint, carsales and trading post.
We get the car early next week after compliance and RWC are done. Edit: I am very restless now, all I can do is post threads and change my profile etc. ;)
These are the pics I just took 30 mins ago when signing papers for RWC.
~Sam
https://www.sau.com.au/forums/topic/65444-after-so-much-searching/
  • Replies 42
Put those Falken ZE-502 tyres (if I have spotted them correctly) STRAIGHT in the bin...
Or never ever drive the car on boost or in the wet. I don't want to see you on the news, those tyres are shithouse. They have no grip, no stiffness and last forever. The treadwear is probably 300 minimum so they are super hard...
That said, the car looks good. Sorry to rain on your parade but I want your car (and you) to be around to have fun!
Nice looking 32 mate... what plans you got for it in the future?
nothing extreme, i'm very happy with the performance it has stock :D
cut and polish to take the scratches off, maybe change the colour of the wheels - i always liked powder coated black on red and white 32s, not sure what will look good on black though.
Edit: a few more pics
The thing under the stereo is the TV; it slides out like a cd player, then you fold it up to face you - and hits the gear stick if it's in 1st or 2nd gear.
Needs a clean
Nice car. I saw it when I went out to look at another 32 that same bloke was selling It looked great. As for the tyres I would agree bin them if you can.
Here is a pic of the stock wheels powder coated on my skyline. i know the car is not black but it might help you decide if you like them
Very tidy leather on the wheel & parkbrake/gearshift boots for an '89!
Your DIN/aircon surround looks textured, is it? I've only only seen smooth.
Looks like quite a tidy car! Might wanna clean the engine bay though :D
angelus: i don't really wanna state the price, but seeing as you're on a skyline site you should be able to work out the cost of a stock 89 gtst in good condition.
cul: i think its smooth but will check
yeah i want an SAU sticker... it will be the only sticker, i assure you all :D
thanks lads :D
yep they are pretty bad. I had them on my last car (32 GTS-T). They're great for doing stupid things tho. I had a heap of fun with them on my 18's @Decca right before I sold the car.
As for modifying it. You will most likely get the urge to do so and a 32 GTS-T is dangerous for the inexperienced. (but heaps of fun still)
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
