Gradenko,
I think we are talking the same language.
Drag/street overlap as much as track/street on turbo selection. The operative word is 'street', ie: nice fat power band.
Whether you have a mild set up for track or strip is a matter of 'how much' you want to compromise the daily drivabillity.
Originally posted by Gradenko
RadiuM, what were you having done to your car, left over compliancing type stuff?
yeah.. .just picking it up from compliancing.. im awaiting the plate this week.. hopefully it'll be here this week. If my plates have been transferred from Rockingham -> Welshpool then it should be licenced by the weekend .. FINALLY!!!! :)
to save on the costs of purchasing the goods+setting them up, prebuy a car with all the goods :D
it saves you a shitload!
Shaun
In my experience, 2 mates with mild mod'd cars (one r32 and one r33) both have done a head gasket (the r32 definately has, the r33 is suspected to have, its running like a dog and displaying the right characteristics). It seems the japanese like to mod their cars, but dont really bother about the servicing and maintenance. Both rev210 and I had fairly stock cars to begin with and both are running extremely well. At the end of the day its all pot luck.
Rob
rev210, yeah, I guess there are extremes to both strip/street and track/street. Just depends on what the individual is comfortable compromising on.
GR33DyMANGO, Danny mentioned he's waiting on parts for your car. Didn't get to see it in the flesh but it seems that wheels are in motion.
initialD, yep its in. Wanna come by and take pics with your digi cam? My dv cam sucks at still shots.
Picked it up yesterday evening and sent it off this morning to have ignition timing adjusted and the s-afc tuned. Also having the fuel pump checked out - now would be a bad time for it to start failing. I took it fairly easy on the short drive home yesterday, but I noticed straight off that it now makes more power on 7psi, untuned, than it previously did on 10psi, tuned. A good sign for things ahead :D
Originally posted by GR33DyMANGO
Gradenko, how do u know about my car?
Because you told me about it.... A few posts back:
if u see my car (silver sII) can u please tell me how its progressing.
Since you asked me to keep a look out, I asked Danny for an update on your behalf :D
Well, picked up the car from Barries today. Interestingly, the new ic is making the car run even richer than before (crazy factory ecu), so the s-afc is leaning back pretty much across the range. Final readout after tuning was 280rwhp. Putting aside the seemingly high reading, its still a decent 30hp increase over the last time it was on the same dyno, so I'm pretty happy :D
Thats a pretty good gain for the same dyno. At least you know something worked (intercooler/s-afc retune).
Does the road feel back up the dyno improvement. Be good if one of us had a g-tech or something.
Yeah, it really does. Previously, putting the boot in <3000rpm in any gear would have the ecu retarding timing all through the rev range. It was pretty severe, I could feel it as it happened and it was annoying. The only way to really start moving when under 3000rpm was to drop it back a gear (or 2), get it by suprise and really go for it. The intercooler changed all that. Now its eager at all revs, doesn't drop timing or do anything silly, just goes for gold.
Heatsoak in the under bonnet intake piping is a big problem though. I can feel it after only a few minutes in traffic. Its becuase of the heat transfer properties of aluminum (piping), good when you're trying to release heat, not so good when you don't want heat. Thermal wrap should help a lot there.
Originally posted by macka
What boost did you run on the dyno
0.95 bar, so around 14psi. Final base timing was set to 18 degrees advance, a couple above what it was previously. Barrie said its as high as we'll be able to take it.
Originally posted by rob77
What intercooler did you go with in the end gradenko?
Don't know the width and height, best I can tell is its 600x300mm and 75mm deep. Made to size by Perfomanz using a tube and fin core to use all space between the indicators. Piping and install by Global Motorworks, across the way from Perfomanz.
rob77, I know you're in love with Jap brands, but this is so well made and such good value for money that, like most other Australian gear, it puts Jap brands to shame. Sorry :D
Hicks, Barrie is of "Barries Dyno and Computer Tune Centre" fame. Works with all sorts, from American muscle to Jap performance and does a lot of work for importers on Jap cars straight off the boat. His workshop has a modest apperance but is always full, his rates are great and most importantly, he knows his shit. Barrie is truly a champ. [end plug] :D
    • Oh ok that makes so much sense. Thanks for clearing it up!
    • And these modern "environmentally friendly" EV vehicles also run on the same smoke! When the engine, wiring, or batteries let it escape it also stops running!
    • Yeah - I found the same information too.. 30% open is like 85% of flow etc. So it's probably going to be minor if not completely imperceptible. I also have a larger pod filter here, will swap that on and see if there's any difference. The hardest part is finding a place to uh, test this. It's quite noticable just how much having ducting to the otherwise completely open pod cools the intake temps down. It's better boxed, or shielded but driving for 30 seconds really makes it plummet to near ambient temperatures. I recall in the past when I was a RB land and had a nice flowing airbox -  - Then I took the lid off and put a pod there, and gained 9 psi of boost and about 60kw from the restriction I didn't know I had - with the controller at same duty cycle. However finding people using over the radiator intakes having similar KPA drops at WOT on built setups makes me think there restriction could be the exhaust or potentially the headers. Either way though, there's no real estate to play with and nothing that can realistically be done about it. The original dyno plot without the airbox, and the larger pod had a better curve. It was later I added the ducting and airbox, and a smaller pod to make it fit in there...
    • That's not completely truthful now is it? Any flex fuelled factory cars also had the option to run on steam.
    • Yeah so I guess your mechanic would know turnaround better than me....but I would have thought you had access to same day or overnight rack rebuilds there....any big city here in Australia has that service.   There are a couple of o-rings and seals involved, I guess the risk is the part is specific not general. Other option is if you can have it on stands in your garage for a while, steering rack removal is pretty simple (2 mounting brackets, 2 ball joints (separate by undoing the nut to the top of the threads, put a pry bar between the steering arm and control arm to put pressure on it then medium force on the side of the ball joint or top of the nut with a hammer to break it free) and then the trickiest bit is the splines to the steering rack (not too bad to undo, one nut then it slides out, but mark it first so you can reassemble it straight)
