82 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
  • Replies 52
Heres some pics of my car with the GT wing just sitting on the boot.
Bear in mind the S1 spoiler is still attached(anyone know how to remove them??) and the GT wing would sit approximately 5-10cm further back than in the pics.
Does anyone know where to get CF bootlids for R33??
:D
You need to get a bosykit and some phat rims to make the wing truly apart of the car. It looks a bit out of place with the stock bodykit
I dont think I'll bother with a body kit but I will probably modify the front bar.
Might consider some rims later but the ones I got are decent -17's..... 255's rear and 235's front
I would've removed the stock spoiler before putting the GT wing on
I removed the stock spoiler today and I'll take a few pics tomorrow.
I've got a bootlid garnish thingy which I will leave on for something different.
Removed the S1 spoiler and Installed the GT wing on friday. Also went and got a quote to fill the holes and respray the boot for $550, a bit pricey but I've seen there work and they do a top notch job.
Heres some pics;
How hard was it to remove the old stock spoiler?
Quite easy actually. After undoing the 4 bolts I ran some fishing line between the spoiler and the bootlid(where possible) to free up the glue stuff and then simply grabbed the wing and pulled firmly upwards untill the clips released it.
y not just get r34 gtr spoiler?
Well scrap that idea. i made a promise last night no more buying fluff for the car. Have to start saving again...so only money to be spend on car is servicing and track days. Only if something breaks am i allowed to buy a new one:(
I think it looks alright and could potentially make the car as a whole look great. Of course it will fit in a lot better if you balance things out.. I recently got an immitation gtr front bar and i think it added heaps to the look of the car. It did cost a bit though - almost 1k inc. painting, installation and mesh. Maybe you should go for a 400R bar. That's a little bit fancier.. it will suit the wing better. But then that might not look quite right until you get some new side skirts.. e.t.c. e.t.c. So much money!
    • Clutch done also about a year ago got a DCS HD Single Plate. Basically done everything but touch the engine 🤣 But will definitely get a fuel pump and ECU, then start saving 🫡
    • Fuel pump and clutch and ecu that’ll get you to about 230 or so kw, after that the sky’s the limit and the budget blows out faster then you can blink
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
