Wow, its a genuine Prodrive Rally Sport 22B Type R V Spec Racing Edition
Now back ontopic:
Prestige and J-Spec are the more common import agents but with the end of the 15 year rule being announced, you have all but lost your chance at getting a well priced R32 GTR into the country. You will soon be able to import one under the RAWS/SEVS system but the costs will be significantly higher for you due to compliance plate costs
Royalstar: The "has to be stock" rule is already in force. The car has to be 100% standard when complied. If the car has minor mods that are easily removed it is possible to bring the car in, return it to stock for compliance then refit parts
Royalstar: very hard to judge. The number of dead stock (or near stock) R32 GT-Rs of sufficient quality (so you aren't risking being knocked back by the RAWS for a damaged car) is not going to be very big. So you have a much smaller number of cars available, and likely more demand for those cars. Although obviously a flawed formula, supply and demand has some relevance and suggests prices are likely to rise (near) stock R32 GT-Rs in good condition.
A higher initial purchase price means that taxes and duties also cost more (though the drop from 15 to 10 percent duty as of 1 Jan 05 will help).
Finally you have the cost of SEVS. Plate prices will again depend on supply and demand: I imagine they will be about $5000 to start with, and drop to $3000-3500 as more RAWS acquire authorisation for R32 plates.
LW.
    • My idle is set at 950rpm though - Moving the timing around 20 degrees is not really what I'd call a calm idle. That said... neither is chop, by definition. The LS ECU likes to adjust timing to hold idle as opposed to air. It'd work, but generally speaking there'd be a discrepancy in the base idle and the IACV would want to move the timing around anyway to maintain said idle. I think I'm just going to keep the timing steady anyway. Preserve my engine mounts.  My aircon is now officially regassed. As the guy was reversing I noticed my reverse lights do not operate, along with my reverse cam. This is a bit distressing, because 100% of guides talk about which wire to connect to backup cams as "the goes with the [other color] wire". Often when doing conversions. Unfortunately the R34 colour wires aren't documented Unfortunately I had a T56 Magnum gearbox with it's reverse switch, which also isn't documented. Unfortunately there's definitely not documentation for people with both of these in the one car. Unfortunately I forgot. After many hours of this, I have a reverse cam and reverse lights again. The wire going through the trans tunnel to the reverse switch had broken. Upon inspection, it looks like this one wire had about 7 spade terminals and extensions in it.. for reasons I cannot possibly comprehend. I also spent the 750 hours required to clean up the wiring behind my head unit which now looks like this: This is a monumental improvement relative to what used to be there WRT triple gauges, head unit, traction control, wideband controller, and whatever the f**k OEM stuff still exists there in various states of connectivity/needed. Next step is to check in at the Exhaust shop to see/confirm how much clearance I have, to decide what mid mufflers or 'resonators' (which are just straight through, narrower mufflers) I can add and hopefully cut out a lot of exhaust leaks, pinhole, v-band or otherwise. But first step will be to 'take a look' before the next step.
    • Fark the AFM card and Nistune, Haltech Nexus S3, DBW, cruise control, flex fuel, dis dat.
    • It's most likely the bolt/bush where the cover bolts back wore and allowed cover to move forward.
    • Still haven't put the injectors and R35 AFM in so we can tune the bloody thing for the HG highflow it got mid last year! I think I can forecast the upgrade path to a bigger twin scroll, external gate, Haltech, flex setup, Samsonas, dis dat, etc will be .... a while away!
    • Should have taken that opportunity to slot in a twin scroll turbo setup. Maybe next time.
