between 125 to 170 (didnt go faster then that) last night the ****ing car would shake badly from the front, as I have never ever had any probs at high speeds, (above 80)before some thing is baddly wrong what do you guys think.
https://www.sau.com.au/forums/topic/65489-bad-shakes-problem/
mostly side to side but smoothed out at about 175, I have just had the disks machianed on the front so I am think they may be causing wobble, but at 0 to 100 its fine. It still handles well at low speed. NO break noise either, it was shaking so bad it was rattleing shit that doesnt ever rattle.
wheel allignment also have you replaced these rotors you said were to thin ???
I have not had wheel allignment yet, but will soon. Its all started after I took the rims off and the disks off. There are machiened rotors but they said that it was fine before they did the job then after told me that they are stuffed.
I'f you've got a steering wheel wobble, then you've most likely lost a weight. It could also be that it was previously balanced on the car to deal with a hub/rotor/tyre balance issue, and removing/refitting the wheel has put it out of balance.
could also be Tail shaft... as you have mentioned you have had you clutch done... tail shaft could be put off... some ar picky, and have to go a certain way on.. if you put them back on, 90deg diff then they tend to shake... yup yup.
wheels tight but will check them again shortly, no weights off wheels that i can see, me thinks the disks are slightly warpped after bad machening (wish I could spell) and only having a prob at high speed. will keep ppl posted as to what it may be.
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
