  • 2 months later...
There are a lot of sensor inputs that go into making the AWD work. There are speed sensors (hijacked from the ABS system), G-sensors, TPS and steering wheel position sensor.
The idea behind it is that the car for as long as possible acts as a RWD. This means that it has the characteristics of oversteer the same as a RWD. The designers didn't want the problem of understeer that constant AWD have (WRX, early EVO's etc...) The important thing to remember is that the front wheels kick in to assist the car and can share anywhere between 0% to 50% of the engine load.
1. Straight line. When the power is put down the front wheels will kick in to keep traction so you get the grip that a WRX has. The more you put your foot into it the more the fronts come in.
2. Cornering. This is a little tricky as it almost works in the operate way. The more lateral (side - cornering) force the car is under the less the front wheels will kick in as this would provoke understeer. Instead, it will wait until the rear end breaks loose then when you go to correct it, pull the front wheels into action so that now all wheels are working to push you in the direction you are steering. This can be disconcerting for many new GTR drivers expecting a typical WRX type AWD experience. This does allow you to still positively steer the car whithout loosing ground from the rear end slide. You keep your foot planted and just point the car where you want to go, letting the front wheel drive pull you out of the power slide. Not to say it is fool proof, you can still get bitten, but careful practice can be rewarding.
So to give you particulars on angles and so on is not possible as the whole system is adjustable depending on so many differing sensor inputs.
https://www.sau.com.au/forums/topic/65505-attesa-specs/#findComment-1359387
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
