Dude, listen to your engine not ur bov - it'll tell you when to change gears :(
BUt what's the use of the BOV then ????
i don't know its job ... thought you have to hear the phst then change gear?
is it better the other way ??? (without  phsssssting)
Okay im gona go down the strip tonight for the first time. Normally when i launch my car i ride my clutch and slowly roll forward then release. Will this give me a faulse start?? Should i have the handbrake up then release it doing this method or should i jst drop the clutch even though  i normally dnt do this way off launching my car.
Should i do a little burn out before i race to will this give me more traction? and should i jst drop the clutch.
Thirdly, what do i need to take helmet etc, and any other points i should consider???
Dude how did you go? What time did ya get? Im gonna head out to run my car when i get my licence back in APR. Untill then all i can do is stare at it and wash it every weekend to keep me sane........... :headspin:
hey benm i read in the other thread on your times...give the nitto's some more try's and then maybe start thinking of another hobby...
anyway, when referring to the stickiness of the strip and street tyres, i didnt think it would be of any benefit if you dropped the psi on them closer to 20psi rather than say the usual 36psi?? am i wrong?
also cant you just go around the water as i remember seeing some cars doing big turns trying to avoid something (which would have been the water), so your tyres are dry and have no need for a burnout as they are street tyres??
yeh.. what happens if you have 4wd like my gts4 does.. and i drive through the water.. i cant imagine my poor 2litre turbo doing massive four wheel spins to get rid of the water i would have just drove through :T
I'm just getting frustrated is all :(
Yeah I went around the water on my last run and even with some slight wheel spin I did my best 60ft of the nite :D
thanks for that benm, another words no need to go through the water for me. However, i am also curious as to how big a burnout you did on the nitto's, as i thought they require a good burnout to get hot enough? and what tyre pressure did you use with the nitto's?
also, do u guys take out the space saver and other little bits in the boot before you run? How much of a difference would 15 odd kg make?
Burnout doesn't exist in my vocabulary (serious). I dont ride the brake and I only do a burnout in first gear so basically no they wouldn't be sticky sticky but they are certainly better than my Michelin 225's so their is room for improvement it's just a matter of getting used to them.
I take out my space saver + jack + subwoofer which is probably 30kg in total. Some cars it helps (less weight) where as other cars it hirts (they need weight over the rear-end).
    • Excuse me, but 2) does apply 1) Would also apply if you consider how much is spent in the alternatives. Also there's the option of 3), buy one pre-built that you can put your family in (it's me, it's my car)   That said, I went on a ~500km drive the other day. I didn't use anything more adventurous than 3rd/4th gear at about ~3000RPM and 50% throttle and I was going as fast as anyone has any sense doing on a public road, with enough grip to the point where I didn't want to go any faster. I was obviously under the limit of the current car etc etc. MX5 with 2.5 N/A to achieve the same speed would be more fun for any road scenario. Maybe consider cams. I wouldn't boost it. The use case is just not there and it won't actually make the car more enjoyable unless you really do plan on wringing gears from 1st to 3rd (at least) at 100% WOT on a public road to 150+kmh.
    • Great if: 1. You had all of the money for everything else that is required  2. Lived in a country where you could actually do this and drive it legally on the road Sadly, neither applies to me As for the turbo, I am having second thoughts, mainly for engineering/registration legality reasons and insurance  Not saying I've finished doing stupid things that I probably should do to the MX5, but boost, and V8 engine swaps isn't on the cards Strange, but true
    • I like this page, better than that silly turbo kit   https://v8roadsters.com/product-category/engine-conversions/engine-conversion-lsx/engine-conversion-lsx-nc/
    • That would be my Shoei helmet
    • Yes shipping here can be a pain, was about to purchase timing belt replacement kit, but it tends to get expensive due to shipping (and customs if importing from non-EU which the UK now falls under).
