The item in the large oval is either your factory boost solenoid or your fuel pressure regulator.
I would guess your factory boost solenoid, but would need a large overview of your enginebay to confirm this...
Do you have aftermarket boost control? e.g. Electronic Boost Controller? This would explain why your factory solenoid has been rendered inoperable by plugging off it's vacuum lines.
https://www.sau.com.au/forums/topic/6551-spot-the-parts/#findComment-97833
Yup... That's your factory boost solenoid.
Since it's been blocked off, you must be running some kind of aftermarket boost control.
You can find it by going to your wastegate actuator (hanging off your turbo's exhaust housing) and following the vacuum lines coming off that until you hit something that looks interesting.
https://www.sau.com.au/forums/topic/6551-spot-the-parts/#findComment-98085
