I got a GTRS installed a month ago and got 255rwkw at 1.2 bar still had standard air flow meter and am getting Z32 tuned this weekend.
My mods are are Full 3 inch exshaust, FMIC, PFC with boost controller, nismo 555cc injectors, exhaust cam, lightened flywheel and ceramic clutch, spitfire coils and bosch 044 fuel pump.
I was wondering is 1.2 bar the max optimal boost level for a gtrs or should I get them to put the boost level maybe 1.4-1.5 bar and will the turbo still be in its efficient range? I believe I need a new head gasket to lower the compression ratio and maybe some forged pistons if i do?
https://www.sau.com.au/forums/topic/65548-hks-gtrs-optimal-boost-level/
  • 2 years later...
Thought I'd save some bandwidth and revive this thread instead of making a new one. Thread Revival FTW!
From research it seems that the HKS GT-RS has the exact same specifcations as the Garrett GT2871R 52T Compressor. If thats the case and assuming that the Skyline version has the same compressor but a custom 0.64 T3 turbine housing, then would someone now be able to tell me the optimal boost range of the GT-RS if I've got the compressor map?
Well here it is. I'd just like to know what kind of boost I should run when I get the car onto the dyno for a tune.
Get the flow map and check, it isn't ahrd to do and there is an excellent how to on this very website on how to read flow maps.. Get to it!!!
Just had a look at that flow chart and it doesn't mean shit to me. So from that graph how can you determine what boost pressure, on an rb25, the turbo goes out of it's efficency range. Can you answer that question? As that is what is being asked. If not it's best to just keep such useless comments to yourself.
Just because you know how to read it, doesn't mean everyone can. Just like the fact i know other shit that you wouldn't know :).
I don't think the turbo will fail.
Just that if you keep pushing, you won't get any gain and the turbo is considered to be choked up and out of it's efficiency if that makes sense.
So yeah, i don't think wheels will start spinning off like the standard if that;s what you mean.
Edited by Birnie
So your saying I could boost the GT-RS up to 28 PSI if i wanted, and it would make it.. ???
but What is the Tip of the Iceberg in relations to how high can I boost it till it *Chokes*?? or doesnt make more power.
Edited by silverbulletR33
once you go out of the compressors efficiency you just dial in more heat
more heat = engine go bang
so running 1.3 bar may give you say 100 units of air at 70deg air temp
running 1.9 bar may give you say 110 units of air at 140deg air temp
bad numbers, but you get the idea
ahh nice thanks :D, it was interesting because, There has been a few examples of RB25's with stock internals pushing 300rwkw with the GT-RS and i was wondering how far out of its efficiency it is, + how much extra heat.
Different dynos. Some dynos are very power happy, or maybe the operator didn't set it up correctly.
Don't take the 300rwkw as gospal, otherwise you are setting yourself up for disappointment :O . Aim for 250-270rwkw; once again Dyno dependant.
There are three things you need to look at on the chart - two are important the other less so.
The FIRST IMPORTANT thing to be looking at is the amount of air (in lbs/min) the turbo will flow. It is this number that determines how much power your car will put out. There is a very strong relationship (largely independent of A/F ratios) between the air flow & the engine output. I am not going to quote a number (You can search & find it elsewhere).
The second important thing is the compressor efficiency. This is a measure of how much heat (ie wasted energy) the compressor puts into the air & therefore theat the I/C needs to remove. The good news is that high 70's are good number & that the islands are pretty flat - typical of a Garret turbo.
The less important number is the pressure ratio of the compressor. As the name suggests this is the ratio of the outlet pressure (ie heading toward to I/C) compared to the inlet pressure (ie just after the AFM's) This turbo can flow a ratio of 3. This is not the same as 2 bar boost (+1 atmosphere) and you will see much less at the MAP sensor.
Remember boost is only a measure of the failure of your induction system to allow air to the engine without restriction. It is nothing to brag about.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
