I have just been having a bit of a think about upgraded turbo selection for a RS4 Stagea and if the specs should be different to a turbo for a Skyline if the same results are desired. I had planed to get a 250kw GCG high flow job for My R33 and may one day want to do an upgrade on the Stagea.
Would the ideal turbo specs for a Stagea be the same as for the Skyline or would a turbo with different characteristics be more suitable when considering the Stageas extra weight and auto trans? I am guessing you would want it to develop peek boost at or just before the torque converter stall / lock up
https://www.sau.com.au/forums/topic/65557-turbo-selection-stagea-vs-skyline/
Hi Burns, I will be using a GCG ball bearing hi flow on our Stagea. With a split dump/engine pipe combo, hi flow cat, 3.25" exhaust and an adjustable exhaust camshaft pulley, I reckon I can tune it for ~0.5 bar at torque converter stall. That's using the Jaycar DFA for fuel tuning and the IEBC to keep the wastegate firmly closed. The power target is 200 4wkw at 1.1-1.2 bar.:(
PS; on the 4wd dyno the Stagea seems to loose around 15 rwkw more than a manual R33GTST does on the same dyno in 2wd. The Stagea was in second with the Snow and 4wd buttons on, as without them the ATTESSA kept moving the power from front to rear on the rollers.
Sounds like the GCG is still probably the best option.
Im getting 172kw at the rear wheels with a front mount, unshielded pod filter, SAFC turbo back Blitz Nur spec exhaust with a non split dump pipe on 12psi. I think I will get the brakes and handling sorted out to my liking before going for any more. Apart from fitting an air box or shield for the pod filter.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
    • Probably a smart choice to buy one vs build, purely for the motivation part as you said! Imagine the metal dust everywhere from grinding all the steel to build one. Ha ha ha!   Also, post a photo of your garage.   Mine is below, this is where I've been cleaning and have already half filled a caged 6*4 trailer. And this is after my cleaning expedition mentioned previously... The middle normally has a car in it, but I'm dumping things in the middle as I sort through them. And poor skyline was dusty and has had the lightest few drops of rain and now it looks atrocious and needs to be dragged back out and washed thoroughly! And yes to the right is technically another bay, you really can only see 2 bays out of 3 in this picture.
    • It's more like on average the things I see a lot of things going wrong. Yes, usually the people who reach out are the ones who are having problems but on average it feels like mechanics and tuners here aren't really competent. I swing between thinking my standards are just way too high and wondering whether people really are just this dumb. I just had the strangest 10+ reply argument on a Facebook group over someone insisting that the factory R34 GTT boost control solenoid reduces boost pressure to 5 psi when it's on and raises boost pressure to 7 psi when it's off despite showing the exact plumbing in the factory service manual and the solenoid behavior detailed in the FSM.
