The whole harness will need to be rewired...the ECU's are way different with the R34 being a fussy bastard with respect to having EVERY sensor working correctly.
As long as you've got the manual to work from, it should be easy enough.
I was just talking to a friend this afternoon about doing such a conversion in the future...
pending on circumstances.
the gearbox will need to be changed, wiring, loom, ecu, basically everything that made the
RB25DET run in the 34 will need to be brought over to the 33
lol ur looking at 10grand mate rofl
6 ish for an engine
then u need bigger brakes
better suspension
bigger fuel pump
as eug said a gearbox and thats around 2 - 3 grand LOL
then theres the installation and that aint cheap mate so basically the engine , gear box, good brakes good suspension and fuel pump will set u back 10grand already if u get suspension , fuel pump and brakes 2nd hand then u'll still be looking at 9grand or so, and then installation of the engine and the complicated wiring the r34 contains will set u back a shit load more.
just put a rb25det into my 32 however it wasnt a neo. pretty straight forward although i didnt personally do it. tailshaft needs to be fabricated as does the gearbox mount. needed to get a new pinnion assembly for speedo going from mech to electrical however not sure if u will encounter this problem being a later model car to start with. i know in queensland regulation states u must have brakes at least the equivalent from whateva car the engine is from, personally i went for s15 as being 4 stud they didnt have to get redrilled or anything and are actually even better then the standard 33 objects i think. (dont quote me on it). depending on diff to my require different diff
cheers, matt
gearbox may hold up if ur gentle. but then again whats the point in havin a turbo car huh??? i looked into this b4 and this is a VERY messy job hey. If its what u wanna do, then go ahead, just make sure u got a fair amount of money in the kitty otherwise ur ride will spend a shitload of time in the shed.
Realistically...the extra cost of putting the NEO in an R33 isn't really worth it..just put in an RB25DET from an R33 and you'll save thousands which could go towards a bigger turbo etc etc which will put you way ahead in power stakes than the mroe expensive NEO
i have read somewhere that the neo6 has a few extra goodies like stronger internals??? (dont quote me on that) which means you can probably run more boost) it makes more power stock like 200ish kw? and has a far greater potential than the standard RB25DET
your fuel pump wont need to be changed, my stocko is running my V8 with nitrous, there a pretty good standard pump, You will need to do the gearbox as yours will probably not handle the power as well as the diff, depending on how u drive, i broke 3 diffs with the rb25de though so maybe im a little harsh on the car. theres not much else u need, brakes can be an afterthought and dont need to be done straight away nor does the suspension. Ive had the V8 in my gts with stock suspension for almost a year now, its a little soft but u can make do with it.
cheers, matt
About the brakes, it depends on what rules u use, there are a number of sets of rules regarding engine conversions, All i had to do is make sure my car had 4 wheel disc brakes.... Mine definately arent up to the task but rules said it was fine.
Depending on where ur from u will more than likely have to get it engineered.
hahhaa. im not to sure wether ur pullin the piss.... so i'll just clarify it. lol. RB25NEO is almost a direct swap into a r33. Onli difference is coilpacks from memory. U can grab the ECU from the r34, not sure if is reprogramable, otherwise just go aftermarket. Then just bolt on turbo, manifold, intercooler, etc. I rekon u could get away with this option for abt 5k.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
    • I agree once misfires happen it's basically worthless, but the hope is you can see what's happening in the run up to that.
    • You should totally get a Brumby, and then come pick up the Subaru Liberty GTB I have here. EJ25 Turbo, 6 speed manual from the sti (just no dccd), and the good rear diff. Drop all that into a Brumby and go have fun!
