Trust33: Interesting comparison, if only I could work out the speed for my 198rwkw graph to do a proper comparison.
I believe i'm changing gears at the right rpm, if I changed any lower i'd lose too much power lower in the gear and have to wait for it to kick in again (like Roy said).
I realise a PowerFC would do me wonders (especially midrange) but that still doesn't explain why other non-PowerFC Skylines are doing better times. Also, i'm trying to improve my times here without spending more money because I believe I have spent enough to get a respectable time :D
Something I realised today whilst driving around Oran Park is that it's taking longer to hit full boost (whether it be 7 or psi) after I change gears. I can actually feel it "kicking in" after I change each gear instead of already being boosted and ready to use like previously.
Bleed valve fault?
Wastegate actuator?
So what roy is saying could be right and loosing that sort of rpm would cause you to loose power in the next gear,and would have more of a detrimental affect on power than i thought.
But when does peak tourqe come in?Usually it is b4 the peak rwkw.Though that close to the peak rwkw you may be way out of your peak tourqe band anyway.
ben, have you had the car on a weigh bridge in race trim, with you in it? Could at least eliminate one more variable for you?
also, interesting point about the boost thing. That's the problem with the dyno it doesn't tell the whole story.
You mean having 2 hotdogs before I race could be part of the problem? Nah haven't had it on a weigh bridge although I know of 1 on Parramatta Rd.
I think I just need afew mechanics to jump in and take it for a drive and just see what they think rather than dyno work.
stick in there mate! Just think if you had just built your motor and then whent out and ran a 10 straight out,it would be too easy ....and where would the fun be in that.Drag racing is all about those thousands of seconds.Everyone you speak to says that drag racing is easy...you only drive in a straight line.Until they figure it out for themselves..So stick in there mate.... there will always be someone quicker than you and also someone slower
My advice get an RB-30 VL and boost it up .
Cheers.
Well I took my car back to my clutch mechanic about 4wks ago (ive been to 3 drag nites in the last 3 weeks) just to get it checked and he said it was grabbing fine, selecting all gears fine... but he didn't actually drive it just sat in the workshop with it.
Although... it doesn't grab as hard as it used to (obviously)... I used to be able to sit in the driveway idling, release the clutch slowly and it would pull the car forward into the garage (no throttle required) where as now the revs sorta dip and it wont pull into the garage without abit of throttle.
Question of the week!  Why are most drag cars automatic?  Mmmm I wonder!!
Because there is too much power for a manual gearbox to transplant to the ground,usually,in the lower gears.So a stall converter is added to give the car maximum power where it is most needed.And the other plus would be no changing of the gears just smooth glide.Meaning not as much time lost shifting and loosing revs etc...
Also, an auto will allow the engine to load (and hence spool turbo) as well as pre-load the drivetrain. A transbrake will hold the auto while it revs to its convertor rpm and then release the car like a slingshot. A manual box simply cannot do this.
  • 1 month later...
    • @joshuaho96 Hmm considering the drama you've seen/experienced, have you looked into getting a built complete long motor shipped from Australia?  Considering the AUD is basically monopoly money when compared to the USD, at a glance this seems like a good option?
    • Bloody Skylines, they put you through the bloody wringer! Stick at it! Stunning drag strip BTW! Where is it? Can see part of the name on the slip and probably should just Google it!
    • I mean the other day I had to walk someone through diagnosing why their timing belt was walking off the cam gears. At least one of the issues was a bent tensioner stud. Local mechanics have found runout on the CAS mechanism causing weird failures. I'm also no saint here I've documented some of the things I've had to learn the hard way. Something I discovered recently is that my CA emissions catalytic converters weren't even welded correctly to align the downpipe to the main cat and they tossed the support bracket that goes from the transfer case to the downpipe to support everything there. I spend a lot of time chasing down these decidedly unsexy problems and the net effect is it feels like I never actually get to the original objective (flex fuel, VCAM, oil control, cooling, etc).
    • At times with how you make everything sound, all I imagine Americans doing when they see a gtr is standing there looking at it and bashing it with a gun like how a caveman would with a club and hoping it fixes itself
    • I think this is just a product of how the US market works for this stuff. Shops are expensive and there's no real way of knowing what kind of results you're going to get, people don't really have the institutional knowledge. I have heard too much at this point to really put faith in anybody "full service" except maybe DSport and they aren't really a full service kind of shop. If you go to the right place I have no doubt they'll get it right for you. Some locals have set it up right but the cost really is nuts and even now they're still fighting issues. And you know I'm a crazy person who thinks things like twin scroll, relatively short low-mount cast headers, PCV recirc to intake, recirculating BOV, right-sized for ~400 whp, MAF load, validating all of that to a standard comparable to OEM test programs, etc are relevant. For what it's worth, multiple local owners at this point have been stuck in a perpetual cycle of blowing a motor -> getting someone to rebuild it -> some missed detail causes the bearings to wipe and spin just outside of break-in mileage or drop valves or some other catastrophe -> cycle repeats. I usually only find out about this because I'm perpetually helping random friends with diagnosing car troubles, Skyline or otherwise. The single turbo stuff if I'm honest is mostly secondary, it just doesn't seem to achieve the numbers in the ~2000-3000 rpm region that I would expect given the results I've seen here or in Motive's videos. I don't really know what we're missing here in the US to be causing this. Lots of people like to emphasize the necessity of finishing the project first and foremost, but I'm not made of money and I can't afford to be trashing a 15k+ USD engine build with any regularity. Or spending my relatively limited garage time these days unable to triangulate problems because too much was changed all at once. Also, even if it isn't a catastrophic failure I would consider spending the cost of single turbo conversion with nothing to show for it to be pretty bad.
