As said before i made 225rwkw at 16psi boost. It was my first time at the runs and only like the third or fourth night id taken my car out since modifying it, so im still not used to the launch.
Anyway 3 out of the 4 runs I had I got in the 13.1 bracket. My final run i was spewing my third wouldnt go in and i was driving the best!!!!!!
Best Time:=
60' 2.175
330' 5.741
660' 8.605
mph 86.82
1000' 11.077
ET 13.142
MPH 106.44
KM/h 171.3
Final Run (Missing third)"=
60' 1.948
330' 5.478
660' 8.632
mph 81.06
1000' 11.206
ET 13.342
MPH 103.02
KM/h 165.79
Im pleased with the results but what time do you reckon i could of got if I didint miss third according to my 60ft etc?
https://www.sau.com.au/forums/topic/65587-my-results-first-time-at-runs/
if you hadn't missed third and managed the same trap speed as the other 13.1 run, with the 1.9 60" time.. you might have got a 13.00 or possibly just in to a 12.99 area.
what wheels/tyres?
how much tyre pressure did you have?
what suspension?
16psi boost? what turbo?
nice work for your first outing..
will get much better as you get used to it
Hey dude, i was next to you in the 13.1 run. Not fair you got more boost than me :(
What car where you in what time did u get?
Ive got 17inch mag wheels on my car and i put the back to 20psi and front i left basically normal. My cars got cut springs, i wana buy sum pineapples but im scared it might slow me down.
Yee ive got a gcg hi flow so my car spools up quickly, but i found my car went the quickest when i got a bit of wheelspin other times i tried not to wheel spin.
I was in the rexy wagon dude, i think i got like 13.8 when i ran you.
I sure did'nt expect you to pull away hehe.
When you going next? i might pose more of a threat then :(
Nice going there man. It takes quite a bit of practice to get the most outta your car on the 1/4 with a manual car.. My 60fts are always 2.4 so I need more practice..
Make sure you get a 12 next time you head out :)
yeee i hope i get a 12 nxt time jst keep my 60 ft down.
bmxwrx: Im going back in couple of weeks coz my mates taking his xr6t in for mods. He ran a 14.3 in auto last night and wana see the difference after the mods. Your cars a sleeper looks stock standard what have you done to it? Im hoping to do a few little mods before i go out next, suspension etc.
I'm running untuned atm with bigger turbo, top mount cooler and 3" zaust. Getting tuned soon, so next time i hope to be in the 12's with ya, gotta get a good jump tho :D providing my clutch is still good for it hehe
Was 14.3 stock for a xr6t? Those whales can get moving real fast once fiddled with, i'm sure you'll find out soon too.
Let me know when you going next dude, we'll have a chat next time.
    • Ok, can confirm.  if you use it like a normal human being in the real world, it works fine.  it only starts crossing wires if I keep using the fob over and over again in a very short period. So if I just chill the f**k out, it works 😂😂
    • Im about to run a e30 mix of e85 and 98ron but i read that australian fuels specifically 98ron doesnt contain ethanol so on the calculator when it says pump ethanol percentage do i just put 0 or is this statement even true? And if it is true i assume i dont need to test any 98ron pumps.
    • So... the fob I had for my Skyline always had this issue where the "Unlock" button worked with no issues but the "Lock" button did nothing (and I always had to lock with the key) I thought I'd try resetting and pairing the key to the car today to see if that fixes the issue. I did the standard steps to program a key but realised my central locking was doing its own thing from time to time. 1st time: The driver-side doors would not lock or unlock when using the fob. No issues with the key. I figured it was the right time to change the battery in the fob so decided to go get one. When I went to the shop all doors locked and unlocked with the fob (while it had the old battery 🙃)   2nd time: When I locked the car, it would lock itself and immediately unlock. If I unlocked it, it would unlock and immediately lock.   3rd time:  After a bit of cursing and praying, that weird bug stopped. But then the rear passenger door started being a pain. It wouldn't really follow what the fob was asking it to do. Sometimes even using the key would not do what I wanted. So I'd lock the car with the key and all doors would lock, but the rear passenger lock didn't do anything at all. And then after a few moments, it would work again.   Is there a fuse that I should be looking at? or, is this one of those things where the door card needs to come off and some unit needs to be replaced? It just seems to happen from time to time and if I give her some space and come back later, there are no issues  🤦‍♂️ Also, should I try to program the fob again to the car just to see if that solves it?
    • One would assume a turbo is somewhere in its future down the line given they slap turbos on pretty much everything that arrives
    • I’m guess it’ll end up with a turbo
